UFL-2LPA-088Y1T-A-100 to SMA cables
------Question for UFL-2LPA-088Y1T-A-100 Please Put your question below------
Can you create 2 m long cables with one end being UFL-2LPA-088Y1T-A-100 and the other, an SMA connector?
Thank you!
Hello raqueladaia,
DigiKey is unable to make custom coax cables.
We also do not have a match to that type of cable, that is 2 meters long, in our system.
Under our product services, we have a tool for building custom RF cables. The length of 2 meters is not available for the connector types that you are looking for.
Checkout to the Taoglas Cable Builder.
Micro-coax cables of a sort suited to use with U.FL style connectors are extremely lossy at common RF frequencies, on the order of 100’s of dB per 100m. A 2-meter length of the stuff would be likely to absorb most of the signal a person put in one end.
