Understanding Dual Circuit Technology in Tactile Switches
Modern electronic systems often require more than a simple ON/OFF signal. Dual Circuit Technology (DCT) allows a tactile switch to provide two independent outputs, helping the system verify that a button press has occurred correctly and detect abnormal conditions.
Figure 1: Dual Circuit Technology Tactile Switch - KSC241J DCT LFS from Littelfuse
What Is Dual Circuit Technology?
Dual Circuit Technology is based on a Single Pole Double Throw (SPDT) switch structure that contains:
Figure 2: DCT Switch Function
  • One Common (COM) contact
  • One Normally Closed (NC) contact
  • One Normally Open (NO) contact
Unlike a standard tactile switch that provides a single output, an SPDT tactile switch provides two signal paths that change state when the button is pressed.
How Does It Work?
For example in its normal state:
Switch State NC Contact NO Contact
Not Pressed Closed Open
Pressed Open Closed
When the button is pressed, the NC contact opens while the NO contact closes. The system can use both signals to verify that the switch has operated correctly.
Signal Verification
Using both NC and NO contacts allows the controller to check whether the expected signal transition has occurred.
For a valid switch operation:
  • NC changes from Closed to Open
  • NO changes from Open to Closed
Any other signal combination can indicate a switch fault, PCB issue, or external circuit problem.
Application Examples - Only One Logic For Correct Execution
[source from Littelfuse]
Benefits of Dual Circuit Technology
  • Provides two independent output signals from a single switch.
  • Enables signal verification using both NC and NO contacts.
  • Supports fault detection by identifying unexpected signal states.
  • Reduces the number of switches and wiring required in a circuit.
  • Integrates multiple functions within a compact switch footprint.
Conclusion
Dual Circuit Technology combines Normally Closed (NC) and Normally Open (NO) contacts within a single SPDT tactile switch. By monitoring both outputs, a system can verify switch operation, detect abnormal signal conditions, and implement more robust control logic using a single compact component.
More technical information about Tactile Switches with Dual Circuit Technology:
SPDT tactile switches available from DigiKey:
Tactile Switches | Switches | DigiKey
Applicable Part Numbers
DigiKey Part Numbers Manufacturer Part Numbers
CKN12186TR-ND,CKN12186CT-ND,CKN12186DKR-ND KSC441J DCT 70 SH LFS
CKN12187TR-ND,CKN12187CT-ND,CKN12187DKR-ND KSC441G DCT 70 SH LFS
679-3571-ND 5GTH935NCNO
108-K5V1GN43T-ND K5V 1 GN 4 3 T
4809-SKSDPBE010TR-ND,4809-SKSDPBE010CT-ND,4809-SKSDPBE010DKR-ND SKSDPBE010
108-TLSMDT3C020GLFSTR-ND,108-TLSMDT3C020GLFSCT-ND,108-TLSMDT3C020GLFSDKR-ND TLSMDT3C020GLFS
108-K5V1YG43T-ND K5V 1 YG 4 3 T
108-K5V4BU43STR-ND,108-K5V4BU43SCT-ND,108-K5V4BU43SDKR-ND K5V 4 BU 4 3 S
108-K5V4BA43STR-ND,108-K5V4BA43SCT-ND,108-K5V4BA43SDKR-ND K5V 4 BA 4 3 S
108-K5V4YG43GHTR-ND,108-K5V4YG43GHCT-ND,108-K5V4YG43GHDKR-ND K5V 4 YG 4 3 G H
108-K5V4BA43GHTR-ND,108-K5V4BA43GHCT-ND,108-K5V4BA43GHDKR-ND K5V 4 BA 4 3 G H
2266-K5V1RD43T-ND,108-K5V1RD43T-ND K5V 1 RD 4 3 T
108-K5V4BU43GHTR-ND,108-K5V4BU43GHCT-ND,108-K5V4BU43GHDKR-ND K5V 4 BU 4 3 G H
108-K5V4GN43GHTR-ND,108-K5V4GN43GHCT-ND,108-K5V4GN43GHDKR-ND K5V 4 GN 4 3 G H
CKN10269-ND K5V1WS43T
2266-K5V2CL43T-ND,CKN10265-ND K5V 2 CL 4 3 T
108-K5V4WH43GCT-ND K5V4WH43G
108-K5V4YG43GTR-ND,108-K5V4YG43GCT-ND,108-K5V4YG43GDKR-ND K5V 4 YG 4 3 G
108-K5V1BU43T-ND K5V 1 BU 4 3 T
5ESH935NCNO-ND 5ESH935NCNO
108-Y71243271FP-ND Y71243271FP
401-1660-2-ND K5V19023G
CKN10268TR-ND K5V2CL43G
401-1661-2-ND K5V1YE43G
401-1663-2-ND K5V1RD43G
CKN10267TR-ND K5V2WX43G
CKN10270TR-ND K5V1WS43G
401-1664-2-ND K5V1YG43G
401-1855-2-ND K5V1WH43G
401-1662-2-ND K5V1GN43G
401-1852-2-ND K5V1BU43G
CKN11529TR-ND,CKN11529CT-ND,CKN11529DKR-ND K5V 4 GN 4 3 G
401-1856-ND K5V1WH43P
401-1859-ND K5V2GN43TP3
401-1862-ND K5V2YE43T
679-3572-ND 5ETH920NCNO
679-3573-ND 5ETH955NCNO
401-1649-ND K5V19023P
401-1650-ND K5V1YE43P
401-1651-ND K5V1GN43P
401-1652-ND K5V1RD43P
401-1654-ND K5V1BU23P
401-1655-ND K5V19023T
401-1656-ND K5V1YE43T
108-KSC241JDCTLFSTR-ND, 108-KSC241JDCTLFSCT-ND, 108-KSC241JDCTLFSDKR-ND KSC241J DCT LFS
