Unknown error when programming CYW920819EVB-02 in IoT Studio
When programming the CYW920819EVB-02 I received an unknown error message (see below). In order to correct this error, I had to recover the board. To do this, you must hold the recover button, press on the reset button, and then release the recover button. Once I had completed this procedure, I was able to program the firmware with out issue.
