I am looking to purchase a replacement USB-C / Thunderbolt connector for an HP ProBook 640 G8 laptop through DigiKey.
(USB 3.1 Gen 1 Type-C with Thunderbolt™ Gen 3 technology (right side))
The connector is soldered directly to the motherboard. I have attached reference images showing the type of connector required.
Based on the available information, it appears to be:
USB Type-C female receptacle
- 24 contacts
- Right-angle / horizontal orientation
- SMT contacts
- Mid-mount PCB design
- Reinforced metal shell with mechanical mounting tabs
- Used for USB-C / Thunderbolt connectivity
Could you please help me identify the DigiKey part number that best matches the connector shown in the attached images?
The most important points are the PCB footprint, contact arrangement, connector height, and mechanical mounting tabs, as the replacement must match the original motherboard layout.
Once the correct part is identified, I would like to order it directly from DigiKey.
Thank you very much for your assistance.
