Value add: DigiKey vs Manufacturer Part Numbers
With some of the Value Added parts, since we are only changing the length of the part, there can be some confusion when only referencing the manufacturers part number. For example (FP-301 1/2" RD 200’) comes in a length of 200ft. We offer the part in several different lengths under the same manufacturers part number. The DigiKey number and description will change for each Value Added Item. We also list on each Product Page if the part is Value Added as seen highlighted below. Ordering under the manufacturer’s part number can cause issues getting the correct length. Please use the DigiKey part number instead to get the appropriate length.
Value Added Examples
Check out this post for additional value added services!
