------Question for FIT0156 Please Put your question below------
Can this switch break 12VDC under a 10 amps load?
I was able to find the datasheet for the manufacturer’s specifications and it does show that it’s rated for up to 10A under 24VDC so it should be viable for 10A, 12VDC.
Here is the document that I found since it isn’t directly linked on DF Robot’s website: https://www.onpowbutton.com/uploads/01dea41937bab58e9fce2ee31dd193ae2.pdf
It says the switch is SPST-NO. I thought e stops were normally closed and when you pushed them they opened the circuit and locked into position. But it says the switch is normally open. Is that right?
