WHa is the cord diameter?
------Question for 6051.2183 Please Put your question below------
Hello christopher.sperry, thank you for the question! According to the datasheet, the type of cable used is H05VV-F3G1.0. Based on some sources for just the cord-set, the approximate dimension should be 8.5mm with some tolerance. I can reach out to the manufacturer for an exact figure if you’d like.
