I’ve been looking more closely at rigid-flex PCB design, and it seems that the challenging part isn’t simply combining rigid and flexible sections. The mechanical transition between the two appears to be particularly important for long-term reliability.
One thing I’m trying to understand better is bend radius. A common starting point I’ve come across is around 10× the flex thickness for static bends, while dynamic applications generally require a larger and more conservative bend radius.
Via placement also seems important. Since vias can create stress concentrations, it makes sense to keep them out of the flex and bend regions whenever possible. I’m curious how strictly designers normally follow this rule in real-world boards, particularly when routing constraints make it difficult.
The rigid-to-flex transition zone is another area that seems easy to overlook. Sharp transitions, components, vias, or other features close to the boundary can introduce additional mechanical stress.
There is also an interesting trade-off with the flex stack-up. Adding layers increases the stiffness of the flexible section, so keeping the flex region to only the layers actually required seems important. Similarly, solid copper planes in a bend area can make the flex section stiffer, which is why copper may need to be reduced, segmented, or hatched depending on the application.
For those who have designed rigid-flex boards for production, what has caused the most problems in practice?
Has it usually been bend radius, via placement, the rigid-to-flex transition, stack-up, copper distribution, or something else?
