What is the component length of B57861S0303F040
------Question for B57861S0303F040 Please Put your question below------
@bangd
For the B57861S0303F040 the below would be the dimensions for this item.
NTC_Mini_sensors_S861.pdf (463.4 KB)
Hi Nathan,
Thank you for your spec. I am looking for this item:
THERMISTOR NTC 30KOHM 3964K BEAD
With component length is 350mm. Please advise.
Thank you,
Bang
@bangd
The order number may be B57861S0303F039 for the 350mm long version.
However I am not seeing that item number listed anywhere to verify that it is orderable.
You will need to contact TDK to see if they are able to support a special order for that version of the B57861S0303F040 that we do list(this one has the shorter leads like the item number you gave.)
Contact | TDK
Thank you so much. I will contact TDK.
Bang
