Question: Why do the Average and RMS measurements produce different results for the same voltage trace?
Answer: Average is the arithmetic mean (including positive and negative signs) over the selected interval, whereas RMS stands for root mean square. For a resistive load, the RMS voltage is the equivalent DC voltage that would produce the same average heating power as the measured waveform.
Consider a sine wave with a 3 V DC offset and a 4 V peak amplitude:
- Over an integer number of complete cycles, the sine-wave AC component averages to zero, so the Average is 3 V.
- The RMS value of the AC component is
4/√2 ≈ 2.828 V. The total RMS is not found by directly adding 3 V and 2.828 V; instead, their mean-square contributions are combined.
Figure 1 : Example sine wave with a DC offset. (Image source: ADI.)
Figure 2 : Calculation of the total RMS value: √(3² + 4²/2) = √17 ≈ 4.123 V. (Image source: ADI.)
Key Takeaway: For this waveform measured over complete cycles, Average represents its DC mean, while RMS accounts for both its DC and AC components.
Related Articles :
- LTspice Waveform Measurements: Average and RMS Values
- What Is the Difference Between Average and RMS in LTspice? Why Are the Results 3 V and 4.123 V?
- How to Check Average and RMS in LTspice with Ctrl+Click?
- How to Use .MEAS to Calculate Average Voltage, RMS Voltage, Current, and Power in LTspice?
- How to Use .STEP and .MEAS to Compare RMS Values at Different DC Offsets in LTspice?
Related ADI References:
- ADI, LTspice: Measuring the Average and RMS Values of a Trace
- LTspice Official Website and Download
- ADI: LTspice: Computing the Average or RMS Value of a Trace
