WHAT IS THE TOOL FOR MFG P/N 2170806-5
------Question for 2170806-5 Please Put your question below------
Hello chirag.parikh,
If you are referring to an installation tool, for the press-fit termination, there is nothing listed as an associated tooling option.
The last page of the Manufacture Datasheet, says “Single port cage assemblies require only flat-rock tooling, while 1xN and stacked assemblies normally require specific application tooling.”
Right below that, are the TE Technical Support Center phone numbers, if you want to check with them about a recommended tooling option.
