------Question for 1218124-4 Please Put your question below------
I needed to know what revision is your stock for the TE part 1218124-4
The PCNs I see that we list for this show a change in marking type(ink to laser) and the removal of the UL / CSA marking for the item.
Otherwise I am not seeing a specific revision change.
Had you found a PCN that shows that there would be a change in the connector revision?
Hello Nathan,
We have some stock but I need more. The REV is H but it is old. The current REV is J.
If you have stock that is REV H I can take this
I see. When you order you can add to your order notes that you would like rev H.
However, If Rev I or J were recent enough H may have already cycled out of our stock.
Would you know when these would have been introduced?
I am not sure when the change has happened.
Is it possible to get a stock check?
Not at this time. Currently you would add to your order notes that you would like the REV H and they will try to accommodate that request. If they are not able to the order team will reach out to you.
