------Question for XXLS-P830845 Please Put your question below------
There are, from my information, at least 2 versions of this speaker. The latest version has the date of July, 2025 on the datasheet from Tymphony/Peerless (btw your link to the datasheet is the dreaded ‘404’ dead link) and has the description of XXLS P830845.REV1.MP1.
Is this the item that you currently have in stock?
Thanks
John
Hello toadhall67,
I brought up the data sheet from MFG Peerless as downloadable from here: Peerless Drivers - Tymphany
Our attributes are also wrong saying that is 20Hz to 2KHz, it should be 20Hz to 1KHz or 20-1000Hz, and for some reason we have it as 7.09ohm impedance. I’m notifying the proper personnel to look at this and fix. The date on this data sheet is from July 2025. We don’t have a different data sheet for this. If the changes have been made the part number did not change to indicate the changes and there is no Product Chane Notification for it either.
The part XXLS-P830845 we have listed on our website should be as indicated on the data sheet.
