Hello, I need a product that has the following ability for my Kief Snake Traps. I need to have it manufactured at minimum qty 50 units.
Operation
When Magnet is removed from the reed switch the device trigger a Loop/Recurring Beep Signal from the sensor itself. Similar to an computer UPS when it lose AC supply.
- The beep need to last for atleast 7 days or longer maintaining the beep to make sure someone will notice it untill they get back home to check on the captured snake.
Needs to work with batteries. Can be rechargeable.
Hi Heke, thanks for your reply. Yes its a very easy straightforward unit. I just need it built.
South Africa
R200
None needed because it is fitted inside an Enclosed Snake Trap. But Dust and Splash Proof is welcome. This alarm in the video needs to be replaced. WhatsApp Video 2025-11-07 at 12.00.33.mp4
Temp Range would be 0-50 degrees celsius
I want to get this manufactured professionally but do not have the resources.
The sound level of the buzzer, i.e. how far it should be audible in rural area? Is pulsed sound OK? (i.e. “beep-beep”, saves battery, extends the perception range)
Beep- Beep is preferred. I take it that you saw the video? My initial idea is that it should sound similar to a Desktop UPS when it lose AC and runs on battery. It’s got a Irritating Loud Beep every 3 or 4 seconds. Sound level I would say about 40 decibels? But anything around that would work great. My main thing is that the battery life needs to keep the beep active for atleast 7 days. Reason being is that you might be on holliday and when you get back you will be notified immediately.
Thanks. Actually, I tried to see the video, but it got stuck, so I quit. Anyway, I saw a snake around your neck, so why do you need the trap? … sorry, a joke. ..
An interesting project and a nice product. I hope someone will take the bait. (I could build that for you, but it would take quite some time). I’ll spread the word.
I am currently working with someone local to develop the alarm but I am afraid that he wont be able to help me build it consumer ready, and not just as a proto type. So I am trying to get a headstart to see who would be able to manufacture them for me.
Regarding rechargeable Lipo battery and charge circuit board check out these options from Adafruit. Batteries Products Category on Adafruit Industries We carried a lot of these. Example charger 1528-1349-ND to be used with a lipo battery such as 1528-1838-ND. There’s a large variety of reed switch sensors (click here) to use with target magnets. Regarding the buzzers please check out the options listed as indicators internally driven. Indicator Buzzers filtered for 3-5V.
