Wire to wire PHR-4
------Question for PHR-4 Please Put your question below------
Hi, what’s the best way to have the PHR-4 connector in a wire to wire layout? Is there a male connector option for that? thanks
Thank you for your inquiry. Unfortunately I was unable to find a cable option for the male counterpart for PHR-4. It looks like there are only board mounted options.
The PHR series from JST are a wire to board connector series. If you want to make them into an inline connector, you will need to solder wires onto the the through hole pins of the header mate.
