ZUSA-PF-324 / DigiKey Part Number 4753-ZUSA-PF-324-ND
Good afternoon,
I’m currently looking for the dimensions for the above item.
Thank you for your help!
Hi @adamaris.lopez
I’ve reached out to the vendor to ask whether a drawing or dimensions are available for this part. I’ll update this post once I hear back.
Good morning Jon,
Is there any update on this? I need it to be 9/16 long if its possible…
Hello @adamaris.lopez
The supplier doesn’t have a drawing or dimensional data for ZUSA-PF-324. They did confirm the following specifications:
  • Material: 304 stainless steel
  • Connection: 3/4" NPT male
  • Style: hex socket plug
  • Pressure class: Class 150
  • Working pressure: 150 psi
  • Specifications met: ANSI/ASME B1.20.1, ASTM A351
If you need the exact overall length or hex socket size, we can’t confirm those for this part.
Best regards!
