Hi Robert,
I am still having the issues with apt-offline installation. The problem is mainly with update. I got the errors:
ERROR: Failed to unlink temproary file /var/lib/apt/lists/partial/deb.debian.org_debian-security_dists_buster_updates_contrib_binary-all_Packages.xzapt-offline. Check respective decompressor library support
deb.debian.org_debian-security_dists_buster_updates_contrib_binary-all_Packages.xz synced
And sometimes I had to manually to twice for installing a package. I have tried many different ways. Here is my steps for offline installation:
On a machine with new installation (Debian 10, buster)
installed apt-offline.deb with dependent files -
sudo apt-offline set update.sig --update
I got error:
Then I gets update first for the machine:
sudo apt-get update -
After update, I did the second step, again
it has no errors. -
sudo apt-offline get update.sig --bundle update.zip
It has errors:
If I ignore these errors, I got installation errors:
If I installed twice with zip files, at end, all updates I needed are installed successfully. But I cannot automate this without errors.
I am not sure, I did right.
Thank you,
David
