12VDC Solar to 1.2VDC Regulator?
You’ll need to use larger mAh capacity batteries with a larger solar panel and a charger that handles the larger solar panel and batteries. Moving from AA to C size will more than double the battery capacity and it will require a more than double size solar panel.
