While this part from TE is available to order, the minimum quantity and lead time can be prohibitive for some.
Product Index ⟩ Relays ⟩ Power Relays, Over 2 Amps
MFR PART # | 1956220-7 |
DIGIKEY PART # | 41-1956220-7-ND |
MANUFACTURER | TE Connectivity Potter & Brumfield Relays |
DESCRIPTION | RE034021 |
DATASHEET | Click Here |
This part from Omron is really close to a direct alternative. As always check the data sheets to be sure it will work for you.
MFR PART # | G6B-1114P-US DC20 |
DIGIKEY PART # | Z3627-ND |
MANUFACTURER | Omron Electronics Inc-EMC Div |
DESCRIPTION | General Purpose Relay SPST-NO (1 Form A) 20VDC Coil Through Hole |
