6 pin surface mount connector
looking for a 6 pin surface mount connector as in the attached picture
Hello srini.koneru,
Welcome to the DigiKey TechForum!
According to the pictures, it looks to be something similar to part A100084CT-ND. The issue that we face, however, is that we cannot tell certain specifications simply by the pictures. We would need measurements of the connector itself, including dimensions and pitch. These measurements correlate with our parameters for searching - you can find a breakdown of what each means HERE.
Once you have the proper measurements, feel free to use the parameters to see if the connector you have is in the following list:
Regards,
Klint
I would also be looking at this potentially being:
S6B-PH-SM4-TB from JST
Thank you for your help , S6B-PH-SM4-TB from JST is the exact match.
