Sn (tin) and Pb (lead) solder alloys are popular leaded solders that are easy to work with, provide for a strong bond, and have a lower melting temperature than lead-free solders but are not as environmentally friendly.
Sn60Pb40 commonly referred to as (60/40) has a plastic range meaning it will stay in liquid form for longer and puts down a slightly thicker coating of solder. This is often preferred for lead tinning and other solder coating applications. The extended plastic range can be preferred for flexibility during soldering however will provide a poor joint if the solder is moved during hardening since the melted solder doesn’t harden at the exact same time across the solder joint. This is an economical solder for less demanding or basic applications.
Sn63Pb37 or (63/37) is eutectic which means it has no plastic range - it melts and solidifies at a single temperature throughout the solder joint providing a consistent and stronger bond then the (60/40) while minimizing cold solder joints. It generally flows better and is the preferred alloy for wave soldering, surface mount soldering, and other applications needing a strong and reliable bond. The added benefit of having a lower melting temperature than the 60/40 is that since it lacks a plastic phase, it has less time to transfer solder heat to the components which may help minimize possible heat damage. This is the preferred solder for demanding applications because of its strong bond and mechanical strength.
Click here for all DigiKey Solder Products.
Related Topics:
Source - Kester: Sn60 vs. Sn63: When is the use of one of these two alloys more appropriate than the other?
Easily Remove Solder Joints: SMD Removal / Desoldering Solder - What is Removal Alloy?
Tin Whiskers in Pure Tin Surface
Nickel Advantages in Tin-Plated Terminals: Surface Contact, Soldering, & Tin Whisker Growth
Fluxing and Cleaning Consideration in Soldering
Good health practices when using Flux
Best Practices for Tinning and Maintaining Your Soldering Iron
Overcoming Challenges When Soldering to Gold and Gold-Plated Surfaces
Summary
KE1104-ND
KE1858-ND
KE1114-ND
KE1116-ND
KE1115-ND
KE1105-ND
KE1106-ND
KE1862-ND
117-44-6040-0050-ND
KE1866-ND
KE1859-ND
KE1864-ND
KE1860-ND
315-NC2SW.0310.5OZ-ND
82-104-ND
KE1867-ND
KE1863-ND
72-T0051403399-ND
82-103-ND
82-105-ND
KE1868-ND
KE1107-ND
473-1160-ND
473-1109-ND
SMD2SW.0312OZ-ND
SMD2SW.0202OZ-ND
315-NC2SW.0151OZ-ND
72-T0051403099-ND
SMD2SW.015100G-ND
72-T0051403199-ND
SMD2SW.0314OZ-ND
BARSN60PB40-8OZ-ND
SMD2SW.0204OZ-ND
315-NC2SW.0152OZ-ND
SMD2SW.0318OZ-ND
SMD2SW.0208OZ-ND
315-NC2SW.0154OZ-ND
BARSN60PB40-ND
2260-WB60/40-ND
NC2SW.0311LB-ND
SMD2SW.0311LB-ND
315-NC2SW.0158OZ-ND
NC2SW.0201LB-ND
SMD2SW.0201LB-ND
473-1128-ND
473-1134-ND
473-1129-ND
473-1130-ND
82-102-ND
473-1114-ND
315-NC2SW.0151LB-ND
315-SMD-SC-SN60PB40-0.031-1OZ-ND
395467-ND
315-CQ-SS-6040-0.76MM-ND
243-1224-ND
315-NC2SW.0200.3OZ-ND
SMD2SW.031.7OZ-ND
SMD2SW.0311OZ-ND
SMD2SW.0201OZ-ND
315-NC2SW.0150.2OZ-ND
72-T0051403299-ND
315-EXB-SN60PB40-ND
473-1132-ND
473-1131-ND
KE1861-ND
473-1164-ND
SMD2SW.020.4OZ-ND
243-1360-ND
KE1608-ND
KE1305-ND
KE1304-ND
14-6040-0125-ND
24-6040-0069-ND
24-6040-0060-ND
KE1829-ND
24-6040-0038-ND
KE1865-ND
24-6040-8802-ND
91-6040-9013-ND
KE1828-ND
24-6040-0007-ND
92-6040-8860-ND
KE1926-ND
26-6040-0061-ND
26-6040-0053-ND
16-6040-0125-ND
26-6040-6411-ND
16-6040-0062-ND
KE1933-ND
KE1604-ND
KE1605-ND
KE1601-ND
KE1117-ND
KE1118-ND
17552-ND
17554-ND
243-1187-ND
473-1161-ND
473-1162-ND
473-1163-ND
473-1110-ND
473-1145-ND
473-1146-ND
4590-1042100-ND
386838-ND
14-6040-0025-ND
14-6040-0040-ND
24-6040-0052-ND
24-6040-2424-ND
24-6040-6417-ND
24-6040-8800-ND
24-6040-8815-ND
24-6040-8817-ND
26-6040-0039-ND
26-6040-0060-ND
26-6040-0103-ND
26-6040-7614-ND
29-4060-0177-ND
91-6040-0007-ND
91-6040-8806-ND
92-6040-0017-ND
92-6040-0026-ND
92-6040-0027-ND
92-6040-8800-ND
315-EXB-SN63PB37-0.5LB-ND
SMD291AX50T3-ND
117-44-6337-0030-ND
SMD291AX250T4-ND
KE1299-ND
KE1300-ND
KE1408-ND
KE1871-ND
KE1101-ND
KE1400-ND
KE1872-ND
KE1873-ND
KE1100-ND
KE1102-ND
KE1109-ND
KE1410-ND
KE1399-ND
KE1402-ND
KE1200-ND
KE1404-ND
KE1108-ND
KE1202-ND
KE1201-ND
KE1409-ND
KE1103-ND
KE1606-ND
KE1301-ND
KE1401-ND
KE1203-ND
KE1405-ND
KE1110-ND
KE1303-ND
24-6337-7402-ND
KE1880-ND
KE1878-ND
315-NCSW.0310.5OZ-ND
82-118-ND
473-1108-ND
16-6337-0125-ND
KE1875-ND
82-119-ND
KE1874-ND
117-96-6337-9531-ND
KE1879-ND
KE1302-ND
SMD2165-ND
117-96-6337-9515-ND
82-113-ND
TS391AX50-ND
SMD291AX-ND
TS391AX-ND
315-EXB-SN63PB37-ND
BARSN63PB37-ND
SMD291AX10T5-ND
2260-WB63/37-ND
4860P-35G-ND
KE1512-ND
KE1603-ND
KE1403-ND
SMD291AX250T5-ND
SMD4300AX250T5-ND
KE1877-ND
70-1002-0510-ND
70-4102-0610-ND
24-6337-8850-ND
315-NCSW.0200.3OZ-ND
RASW.0311OZ-ND
RASW.0201OZ-ND
RASW.0312OZ-ND
RASW.0202OZ-ND
473-1107-ND
473-1111-ND
RASW.0314OZ-ND
SMDSW.0202OZ-ND
RASW.0204OZ-ND
315-NC191AX15T5-ND
2260-WBRA633731-4OZ-ND
2260-WBNCC633731-4OZ-ND
2260-WBNCC633720-4OZ-ND
RASW.015100G-ND
SMD2215-25000-ND
SMDSW.015100G-ND
SMD2200-25000-ND
SMD2205-25000-ND
SMDSW.0314OZ-ND
SMD2195-25000-ND
315-NC191AX35-ND
SMD2190-25000-ND
SMDSW.0204OZ-ND
SMD2185-25000-ND
SMD291AXT4-ND
2260-WB63/37-1/2LB-ND
SMD2180-25000-ND
SMD2165-25000-ND
2260-SSWS-35G-ND
SMD2150-25000-ND
SMD2140-25000-ND
SMD4300AX10-ND
DKS-SOLDERPASTE15G-ND
315-NC191AX35T5-ND
SMDSW.0318OZ-ND
315-NC191AX50T5-ND
SMD291AX10T4-ND
TS391AX10-ND
SMD4300AX10T4-ND
RASW.0318OZ-ND
RASW.0208OZ-ND
SMD4300AX10T5-ND
2260-SSWS-T5-50G-ND
82-117-ND
82-134-ND
315-WS991AX35T4-ND
SMDSW.0311LB-ND
RASW.0311LB-ND
NCSW.0311LB-ND
473-1133-ND
NCSW.0201LB-ND
RASW.0201LB-ND
SMDSW.0201LB-ND
2260-WBNCC633732-ND
2260-WBRC63/3762-ND
315-NC191AX250-ND
2260-WBRC63/3732-ND
473-1125-ND
473-1124-ND
2260-WBRA633720-1LB-ND
SMD4300AX250T4-ND
82-114-ND
TS391AX250-ND
82-132-ND
473-1157-ND
82-129-ND
KE1876-ND
473-1112-ND
473-1156-ND
SMD291AX500T3C-ND
SMD2185-ND
2260-SSWS-T5-250G-ND
TS391AX500C-ND
SMD2170-ND
SMD2150-ND
70-0102-0611-ND
70-4102-0611-ND
2260-WBRA633720-4OZ-ND
2260-WBWS633731-1LB-ND
2260-SSWS-250G-ND
315-NC191AX500C-ND
SMD2180-ND
SMD2140-ND
315-SMD-SC-SN63PB37-0.031-1OZ-ND
315-EXLB-SN63PB37-ND
SMD2215-ND
315-EXLB-SN63PB37-20LB-ND
SMD291AX10-ND
SMD291AXT5-ND
KE1507-ND
SMD291AX250T3-ND
117-44-6337-0050-ND
KE1510-ND
RASW.031.7OZ-ND
2260-WBNCC633731-2OZ-ND
2260-WBWS633731-2OZ-ND
2260-WBRA633731-2OZ-ND
SMDSW.0311OZ-ND
SMDSW.0201OZ-ND
2260-WBWS633720-2OZ-ND
2260-WBRA633720-2OZ-ND
2260-WBNCC633720-2OZ-ND
315-NC191AX15-ND
2260-WBWS633731-4OZ-ND
315-NC191AX50-ND
SMD2170-25000-ND
SMDSW.0208OZ-ND
315-TS991AX35T4-ND
473-1113-ND
SMD4300AX250T3-ND
2260-WBWS633720-1LB-ND
473-1126-ND
82-130-ND
82-128-ND
82-127-ND
82-121-ND
473-1158-ND
315-NC191AX250T5-ND
SMD2200-ND
315-WS991AX500T4-ND
SMDSW.031.7OZ-ND
RASW.020.4OZ-ND
SMDSW.020.4OZ-ND
SMDSW.0312OZ-ND
2260-WBWS633720-4OZ-ND
BARSN63PB37-8OZ-ND
473-1127-ND
473-1159-ND
SMD2195-ND
2260-WBNCC633720-ND
SMD291AX500T3-ND
4590-1179443-ND
2260-SSNC-15G-ND
4590-389283-ND
2260-SSNC-T5-15G-ND
2260-SSWS-15G-ND
2260-SSWS-T5-15G-ND
2260-SSNC-35G-ND
2260-SSWS-50G-ND
2260-SSNC-T5-35G-ND
2260-SSNC-T5-50G-ND
117-4763370050-ND
19-6337-0125-ND
2260-SSWS-T5-35G-ND
4590-1179441-ND
315-SMD291AX10T6-ND
M00515-ND
24-6337-7600-ND
14-6337-0125-ND
24-6337-7614-ND
KE1869-ND
KE1831-ND
KE1199-ND
24-6337-0069-ND
92-6337-6416-ND
24-6337-8846-ND
315-JET551AX10T5-ND
24-6337-8825-ND
24-6337-8860-ND
KE1830-ND
91-6337-8843-ND
92-6337-8809-ND
KE1833-ND
KE1870-ND
24-6337-8804-ND
24-6337-7602-ND
24-6337-8808-ND
24-6337-8842-ND
KE1513-ND
24-6337-7604-ND
117-70-1708-0504-ND
92-6337-6420-ND
KE1508-ND
24-6337-8853-ND
1354296-ND
2260-SSNC-T5-250G-ND
SMD2205-ND
SMD4300AX500T3C-ND
SMD2190-ND
315-JET551AX30T5-ND
24-6337-7403-ND
SMD291AX500T4C-ND
SMD4300AX500T4C-ND
315-SMD291AX250T6-ND
24-6337-7420-ND
315-TS991AX500T4-ND
70-1003-0510-ND
24-6337-7400-ND
70-0202-0510-ND
24-6337-7415-ND
KE1509-ND
7021020510-ND
MMF006622-ND
70-2102-0610-ND
70-1302-0510-ND
70-1003-0511-ND
70-1002-0511-ND
70-0102-0610-ND
70-0202-0511-ND
70-2103-0511-ND
70-2102-0511-ND
70-1003-0610-ND
70-0202-0610-ND
70-0902-0511-ND
70-0902-0510-ND
70-2102-0611-ND
315-NC191AX500T5C-ND
70-1302-0511-ND
70-1003-0611-ND
70-0202-0611-ND
KE1514-ND
24-6337-0001-ND
24-6337-8810-ND
SMD291AX500T5-ND
24-6337-8870-ND
SMD291AX500T5C-ND
SMD4300AX500T5C-ND
70-0102-0519-ND
70-2002-0511-ND
16-6337-0062-ND
26-6337-8817-ND
70-0102-0618-ND
18-6337-0081-ND
KE1600-ND
KE1111-ND
KE1112-ND
KE1113-ND
KE1406-ND
KE1407-ND
KE1511-ND
KE1516-ND
4590-386839-ND
4590-386840-ND
4590-395442-ND
4590-386825-ND
4590-386826-ND
82-120-ND
4590-397982-ND
4590-MM01075-ND
4590-554889-ND
4590-583489-ND
24-6337-7618-ND
24-6337-7612-ND
24-6337-7616-ND
24-6337-7601-ND
14-6337-0015-ND
16-6040-0031-ND
16-6040-0050-ND
473-1143-ND
473-1144-ND
389289-ND
4590-403674-ND
4590-818006-ND
1354298-ND
544784-ND
4860P-250G-ND
4885WS-454G-ND
4860P-500G-ND
117-77-6337-0030-ND
117-77-6337-0050-ND
117-77-6337-1930-ND
18-6337-0093-ND
18-6337-0118-ND
24-6337-0017-ND
24-6337-0026-ND
24-6337-0060-ND
24-6337-6407-ND
24-6337-6410-ND
24-6337-7603-ND
24-6337-7615-ND
24-6337-7617-ND
24-6337-7631-ND
24-6337-8213-ND
24-6337-8267-ND
24-6337-8500-ND
24-6337-8803-ND
24-6337-8811-ND
24-6337-8816-ND
24-6337-8843-ND
24-6337-9628-ND
24-6337-9706-ND
24-6337-9735-ND
24-6337-9758-ND
24-6337-9832-ND
28-6337-6470-ND
70-2002-0611-ND
70-2102-0519-ND
85-6337-0118-ND
91-6337-6400-ND
91-6337-6415-ND
91-6337-8806-ND
91-6337-8807-ND
91-6337-8834-ND
KE1823-ND
91-6337-9727-ND
91-6337-9815-ND
92-6337-0007-ND
92-6337-6402-ND
92-6337-8802-ND
92-6337-8803-ND
92-6337-8825-ND
92-6337-8834-ND
KE1834-ND
92-6337-9702-ND
92-6337-9710-ND
KE1836-ND
92-6337-9727-ND
KE1839-ND
1405711-ND
24-6040-0061
24-6040-0026
24-6040-0066
24-6040-0018
24-6040-0053
24-6040-0039
24-6040-0027
24-6040-9710
44-6040-0050
24-6040-9718
24-6040-9702
24-6040-9713
24-6040-9703
NC2SW.031 0.5OZ
386824
24-6040-9720
24-6040-9711
T0051403399
386827
389261
24-6040-9721
24-6040-0010
4890-18G
4870-18G
SMD2SW.031 2OZ
SMD2SW.020 2OZ
NC2SW.015 1OZ
T0051403099
SMD2SW.015 100G
T0051403199
SMD2SW.031 4OZ
BARSN60PB40-8OZ
SMD2SW.020 4OZ
NC2SW.015 2OZ
SMD2SW.031 8OZ
SMD2SW.020 8OZ
NC2SW.015 4OZ
BARSN60PB40
WB60/40
NC2SW.031 1LB
SMD2SW.031 1LB
NC2SW.015 8OZ
NC2SW.020 1LB
SMD2SW.020 1LB
4894-227G
4875-227G
4895-227G
4896-227G
386832
4895-454G
NC2SW.015 1LB
395467
CQ-SS-6040-0.76MM
17553
NC2SW.020 0.3OZ
SMD2SW.031 .7OZ
SMD2SW.031 1OZ
SMD2SW.020 1OZ
NC2SW.015 0.2OZ
T0051403299
EXB-SN60PB40
4898-227G
4897-227G
24-6040-9709
4898-454G
SMD2SW.020 .4OZ
17551
14-6040-0062
24-6040-6403
24-6040-6411
14-6040-0125
24-6040-0069
24-6040-0060
92-6040-8846
24-6040-0038
24-6040-9715
24-6040-8802
91-6040-9013
92-6040-8801
24-6040-0007
92-6040-8860
26-6040-0069
26-6040-0061
26-6040-0053
16-6040-0125
26-6040-6411
16-6040-0062
28-6040-0061
14-6040-0031
14-6040-0020
04-6040-0000
23-6040-0027
23-6040-0018
17552
17554
17555
4894-454G
4896-454G
4897-454G
4875-454G
4876-227G
4877-227G
1042100
386838
14-6040-0025
14-6040-0040
24-6040-0052
24-6040-2424
24-6040-6417
24-6040-8800
24-6040-8815
24-6040-8817
26-6040-0039
26-6040-0060
26-6040-0103
26-6040-7614
29-4060-0177
91-6040-0007
91-6040-8806
92-6040-0017
92-6040-0026
92-6040-0027
92-6040-8800
EXB-SN63PB37-0.5LB
SMD291AX50T3
44-6337-0030
SMD291AX250T4
24-6337-6411
24-6337-6403
24-6337-8801
24-6337-9702
24-6337-0039
24-6337-8800
24-6337-9710
24-6337-9711
24-6337-0061
24-6337-0027
24-6337-0018
24-6337-8802
24-6337-8817
24-6337-8814
24-6337-9713
24-6337-8809
24-6337-0053
24-6337-9718
24-6337-9700
24-6337-8834
24-6337-0010
14-6337-0031
24-6337-6401
24-6337-8807
24-6337-9703
24-6337-8806
24-6337-0007
24-6337-6422
24-6337-7402
24-6337-9756
24-6337-9744
NCSW.031 0.5OZ
386927
4865-454G
16-6337-0125
24-6337-9716
450314
24-6337-9715
96-6337-9531
24-6337-9746
24-6337-6417
SMD2165
96-6337-9515
392249
TS391AX50
SMD291AX
TS391AX
EXB-SN63PB37
BARSN63PB37
SMD291AX10T5
WB63/37
4860P-35G
70-1708-0520
14-6337-0062
24-6337-8813
SMD291AX250T5
SMD4300AX250T5
24-6337-9727
70-1002-0510
70-4102-0610
24-6337-8850
NCSW.020 0.3OZ
RASW.031 1OZ
RASW.020 1OZ
RASW.031 2OZ
RASW.020 2OZ
4860-18G
4880-18G
RASW.031 4OZ
SMDSW.020 2OZ
RASW.020 4OZ
NC191AX15T5
WBRA633731-4OZ
WBNCC633731-4OZ
WBNCC633720-4OZ
RASW.015 100G
SMD2215-25000
SMDSW.015 100G
SMD2200-25000
SMD2205-25000
SMDSW.031 4OZ
SMD2195-25000
NC191AX35
SMD2190-25000
SMDSW.020 4OZ
SMD2185-25000
SMD291AXT4
WB63/37-1/2LB
SMD2180-25000
SMD2165-25000
SSWS-35G
SMD2150-25000
SMD2140-25000
SMD4300AX10
DKS-SOLDERPASTE15G
NC191AX35T5
SMDSW.031 8OZ
NC191AX50T5
SMD291AX10T4
TS391AX10
SMD4300AX10T4
RASW.031 8OZ
RASW.020 8OZ
SMD4300AX10T5
SSWS-T5-50G
386844
386820
WS991AX35T4
SMDSW.031 1LB
RASW.031 1LB
NCSW.031 1LB
4865-227G
NCSW.020 1LB
RASW.020 1LB
SMDSW.020 1LB
WBNCC633732
WBRC63/3762
NC191AX250
WBRC63/3732
4885-227G
4884-227G
WBRA633720-1LB
SMD4300AX250T4
397102
TS391AX250
386818
4886-454G
386851
24-6337-9717
4885-454G
4884-454G
SMD291AX500T3C
SMD2185
SSWS-T5-250G
TS391AX500C
SMD2170
SMD2150
70-0102-0611
70-4102-0611
WBRA633720-4OZ
WBWS633731-1LB
SSWS-250G
NC191AX500C
SMD2180
SMD2140
EXLB-SN63PB37
SMD2215
EXLB-SN63PB37-20LB
SMD291AX10
SMD291AXT5
70-1607-0520
SMD291AX250T3
44-6337-0050
70-0102-0511
RASW.031 .7OZ
WBNCC633731-2OZ
WBWS633731-2OZ
WBRA633731-2OZ
SMDSW.031 1OZ
SMDSW.020 1OZ
WBWS633720-2OZ
WBRA633720-2OZ
WBNCC633720-2OZ
NC191AX15
WBWS633731-4OZ
NC191AX50
SMD2170-25000
SMDSW.020 8OZ
TS991AX35T4
4886-227G
SMD4300AX250T3
WBWS633720-1LB
4887-227G
395465
386862
395451
386876
4887-454G
NC191AX250T5
SMD2200
WS991AX500T4
SMDSW.031 .7OZ
RASW.020 .4OZ
SMDSW.020 .4OZ
SMDSW.031 2OZ
WBWS633720-4OZ
BARSN63PB37-8OZ
4888-227G
4888-454G
SMD2195
WBNCC633720
SMD291AX500T3
1179443
SSNC-15G
389283
SSNC-T5-15G
SSWS-15G
SSWS-T5-15G
SSNC-35G
SSWS-50G
SSNC-T5-35G
SSNC-T5-50G
4763370050
19-6337-0125
SSWS-T5-35G
1179441
SMD291AX10T6
550014
24-6337-7600
14-6337-0125
24-6337-7614
24-6337-0652
92-6337-8801
24-6337-9721
24-6337-0069
92-6337-6416
24-6337-8846
JET551AX10T5
24-6337-8825
24-6337-8860
92-6337-8800
91-6337-8843
92-6337-8809
92-6337-8860
24-6337-0657
24-6337-8804
24-6337-7602
24-6337-8808
24-6337-8842
57-3901-5607
24-6337-7604
70-1708-0504
92-6337-6420
70-1607-0504
24-6337-8853
1354296
SSNC-T5-250G
SMD2205
SMD4300AX500T3C
SMD2190
JET551AX30T5
24-6337-7403
SMD291AX500T4C
SMD4300AX500T4C
SMD291AX250T6
24-6337-7420
TS991AX500T4
70-1003-0510
24-6337-7400
70-0202-0510
24-6337-7415
70-0102-0510
70-2102-0510
MMF006622
70-2102-0610
70-1302-0510
70-1003-0511
70-1002-0511
70-0102-0610
70-0202-0511
70-2103-0511
70-2102-0511
70-1003-0610
70-0202-0610
70-0902-0511
70-0902-0510
70-2102-0611
NC191AX500T5C
70-1302-0511
70-1003-0611
70-0202-0611
70-2002-0510
24-6337-0001
24-6337-8810
SMD291AX500T5
24-6337-8870
SMD291AX500T5C
SMD4300AX500T5C
70-0102-0519
70-2002-0511
16-6337-0062
26-6337-8817
70-0102-0618
18-6337-0081
04-6337-0000
23-6337-0027
23-6337-0018
23-6337-0007
23-6337-8807
23-6337-8806
57-3201-4815
57-3201-5515
386839
386840
395442
386825
386826
386857
397982
MM01075
554889
583489
24-6337-7618
24-6337-7612
24-6337-7616
24-6337-7601
14-6337-0015
16-6040-0031
16-6040-0050
4866-227G
4867-227G
389289
403674
818006
1354298
544784
4860P-250G
4885WS-454G
4860P-500G
77-6337-0030
77-6337-0050
77-6337-1930
18-6337-0093
18-6337-0118
24-6337-0017
24-6337-0026
24-6337-0060
24-6337-6407
24-6337-6410
24-6337-7603
24-6337-7615
24-6337-7617
24-6337-7631
24-6337-8213
24-6337-8267
24-6337-8500
24-6337-8803
24-6337-8811
24-6337-8816
24-6337-8843
24-6337-9628
24-6337-9706
24-6337-9735
24-6337-9758
24-6337-9832
28-6337-6470
70-2002-0611
70-2102-0519
85-6337-0118
91-6337-6400
91-6337-6415
91-6337-8806
91-6337-8807
91-6337-8834
91-6337-9703
91-6337-9727
91-6337-9815
92-6337-0007
92-6337-6402
92-6337-8802
92-6337-8803
92-6337-8825
92-6337-8834
92-6337-8872
92-6337-9702
92-6337-9710
92-6337-9713
92-6337-9727
92-6337-9756
1405711
