This post is for informational purposes only. Please review the manufacturer’s specifications before using any part as a replacement.
7000-13562-9720050 is a 0.5 meter M12 cable, from Murrelektronik, Inc. Though we do distribute for them we do not carry this particular model, however if you need a stocking alternate we carry 5088-7000-13562-9720020-ND which is the same but with a shorter 0.2 meter cable.
If you need an equivalent with the original length, I’d recommend 1195-4106-ND from HARTING. I recommend this one specifically because as well as the connector itself, the color coding on the cable is similar to the Murrelektronik version.
