900-1462360051-ND vs WM22479-ND
Hello team
For one of our project, we had called up following RFID anteena earlier.
Details : 1462360051
Digi-Key Part Number 900-1462360051-ND
Manufacturer Molex
Manufacturer Product Number 1462360051
Description NFC ANTENNA TAG 15X15MM
Now my team is suggesting to procure the following one
1462360001
Digi-Key Part Number WM22479-ND
Manufacturer Molex
Manufacturer Product Number 1462360001
Description RECTANGLE STANDARD NFC ANTENNA 1.
Could you please help to find out if practically, is there any difference in the above two RFID anteenas?
Thanks Rajesh Gupta
Hello Rajesh Gupta,
It appears that the difference between these two RFID antennas is size.
900-1462360051-ND has the dimensions 15.00mm x 15.00mm x 0.17mm while WM22479-ND has the dimensions 15.00mm x 25.00mm x 0.17mm.
Correct reply…Thank. It solved the purpose
