In the middle of most Aavid Technology heat sink part numbers you will see a letter and then at the end you will often see a “G”
The letter in the middle is calling out the Finish on the part. Here are the available Letter Codes.
| Letter | Finish |
| A | Hard Anodized |
| B | Black Anodized |
| PB | Pre-Anodized Black Material |
| B-TT | Black enamel Paint with Tinned Tabs |
| L | Clear Chromate |
| C | Gold Chromate |
| D | Tin Plate |
| PD | Pre-Tinned Copper Material |
| R | Red Anodized |
| U | Clean/Unfinished |
The “G” at the end of the part number is calling out a RoHS compliant part.
Example: Looking at part 577202B00000G the “B” is calling out Black Anodized and the “G” again is calling out RoHS
Applicable Heat Sink Part Numbers
HS115-ND HS105-ND HS106-ND HS338TR-ND HS338CT-ND HS338DKR-ND HS112-ND HS107-ND HS227-ND HS104-2-ND HS360-ND HS121-ND HS408-ND HS336-ND HS407-ND 573100D00010GTR-ND 573100D00010GCT-ND HS273-ND HS346-ND HS351-ND HS300-ND 7109D/TRGTR-ND 7109D/TRGCT-ND 7109D/TRGDKR-ND HS387-ND HS406-ND HS369-ND HS412-ND 7021B-MTG-ND 6396BG-ND 6236BG-ND HS380-ND HS420-ND 533002B02551G-ND HS257-ND HS405-ND 533402B02552G-ND 6400BG-ND HS374-ND HS264-ND 375424B00034G-ND HS507-ND HS111-ND 575002B00000-ND HS116-ND HS341-ND HS365-ND 574902B00000G-ND 7020BG-ND HS337-ND HS367-ND HS368-ND HS372-ND HS198-ND HS333-ND HS113-ND HS230-ND HS104-1-ND HS402-ND HS415-ND HS216-ND HS371-ND HS189-ND HS114-ND HS251-ND HS215-ND HS339TR-ND HS339CT-ND HS339DKR-ND HS220-ND 574902B03700G-ND HS179-ND 580100B00000G-ND HS358-ND HS366-ND HS409-ND HS373-ND HS357-ND 501100B00000G-ND 7020B-MTG-ND HS207-ND 7025B-MTG-ND HS416-ND 6021BG-ND HS414-ND 7139DG-ND HS148-ND HS231-ND HS218-ND 6025DG-ND HS352-ND HS149-ND HS193-ND HS411-ND 6043BG-ND HS382-ND HS110-ND HS278-ND HS410-ND HS377-ND HS276-ND HS194-ND HS370-ND HS388-ND 6222BG-ND HS404-ND HS349-ND HS355-ND 7019B-MTG-ND HS100-ND 593101B03600G-ND HS236-ND HS259-ND HS253-ND HS389-ND 529901B02500G-ND 6022BG-ND HS242-ND 6223BG-ND 7022B-MTG-ND HS386-ND HS101-ND HS110-3-ND 563002D00000G-ND 6230DG(COPPER)-ND HS343-ND HS342-ND 533422B02552G-ND HS255-ND HS481-ND HS486-ND HS504-ND HS496-ND HS364-ND 591202B04000G-ND HS359-ND HS214-ND 523002B00000-ND HS221-ND 574502B03200G-ND 573902B00000G-ND HS413-ND 6030D(COPPER)G-ND 542502D00000G-ND HS248-ND 542502B00000G-ND 325705B00000G-ND 6225B-MTG-ND 529701B02500G-ND 532602B02500G-ND HS385-ND 505403B00000G-ND 533802B02500G-ND HS340-ND HF20G-ND HS335-ND HS142-ND HS260-ND 591202B03700G-ND 563202D00000G-ND 7024B-MTG-ND 531202B02100G-ND HF35G-ND HS477-ND HS480-ND 576802B00000W/TAB038326-ND 6230B-TTG-ND 6025B-TTG-ND 532702B02500G-ND HS483-ND HS505-ND HS511-ND HS509-ND HS513-ND 573902B04000G-ND HS228-ND 590302B03600G-ND 7142DG-ND 320105B00000G-ND HS479-ND HS478-ND HS499-ND HS500-ND HS482-ND HS484-ND HS502-ND HS501-ND HS503-ND HS490-ND HS492-ND HS493-ND HS489-ND HS497-ND HS495-ND HS494-ND HS487-ND HS488-ND HS491-ND HS512-ND HS506-ND HS498-ND HS508-ND HS510-ND HS515-ND HS517-ND HS516-ND HS514-ND HS519-ND HS287-ND TV-4G-ND HS403-ND HS347-ND HS350-ND HS375-ND 6398BG-ND HS485-ND HS518-ND 501000B00000G-ND 592502B00000G-ND 593002B00000G-ND 576802B03300G-ND 575400B00000G-ND 575502B00000G-ND 591202B03100G-ND 591302B04000G-ND 6273B-ND 574802B00000G-ND 574602B00000G-ND 7019BG-ND 574602B03300G-ND 506902B00000G-ND HS247-ND 573400D00000G-ND 507222B05300G-ND 7024BG-ND 578105B00000G-ND 513002B00000-ND 6271B-ND 530714B05300G-ND 530510B00000G-ND 566902B00000G-ND 592502B02800G-ND 576012B00000G-ND 7025BG-ND 574402B00000G-ND HS217-ND 575300B00000G-ND 578405B00000G-ND 560200B00000G-ND 579604B00000G-ND 513101B00000-ND HS361-ND 7021BG-ND 573902B03900G-ND 335314B00000G-ND 513001B02500G-ND 7137DG-ND 7023BG-ND 563202B00000G-ND 508600B00000G-ND 7178DG-ND 7140DG-ND 7038BG-ND 513202B02500G-ND HS303-ND 566902B04000G-ND 550302B00000-ND HS182-ND 513301B02500G-ND HS119-ND 529801B00000-ND HS181-ND 533002B02500G-ND 513302B02500G-ND 574802B03700G-ND 6238BG-ND 550402B00000-ND HS274-ND 335814B00000G-ND 335714B00000G-ND 7121DG-ND 574102B03300G-ND 7129DG-ND 574802B03300G-ND 531002B02100G-ND 550102B00000-ND 533201B02500G-ND 533202B02500G-ND 530001B00000-ND 593202B03400G-ND 6239BG-ND 532602B00000-ND 507002B05300G-ND 529901B00000-ND 529902B00000-ND 578902B03200G-ND 581101B02500G-ND 531102B02100G-ND 574102B03700G-ND 6084BG-ND 7106D/TRG-ND 575703B00000G-ND 529701B02100G-ND 6396B-P2G-ND 529801B02100G-ND 311505B00000G-ND 533101B02551G-ND 513101B02500G-ND 579704B00000G-ND 335214B00000G-ND 566010B00000G-ND 552703B00000-ND 533102B02551G-ND 575603B00000G-ND HS180-ND 530001B02100G-ND 581102B02100G-ND 6399B-P2G-ND 6399BG-ND 533602B02500G-ND 533701B02552G-ND 6239B-MTG-ND 552803B00000G-ND 552844B00000-ND 575803B00000G-ND 533402B02500G-ND 7138DG-ND 529902B02100G-ND 533702B02552G-ND 533722B02552G-ND 6038BG-ND 533202B02551G-ND HS379-ND 6038DG-ND 7148DG-ND 576602D00000G-ND 566102B00000G-ND 6232B-MTG-ND 523002D00000G-ND 7021B-MT6G-ND 575002D00000G-ND 530614B05300G-ND 335314B00032G-ND 6045B-ND 581002B02100G-ND 529901B02100G-ND 592902B03400G-ND 335214B00032G-ND 2328BG-ND 311505A00000G-ND 584000B03300G-ND 533502B02552G-ND 530101B00100G-ND 326005R00000G-ND HS140-ND 325705R00000G-ND 575903B00000G-ND 533302B02551G-ND 580100W00000G-ND 530801B05150G-ND HS381-ND 6109BG-ND 532802B02500G-ND 7130DG-ND 530802B05100G-ND 530400B00100G-ND 533522B02552G-ND 2342B-ND 501806B00000G-ND 508222B00000-ND 6000DG-ND 506003B01300-ND 530801B05100G-ND 502006B00000G-ND 501706B00000G-ND 560700B00000-ND 6400B-P2G-ND 6263B-MT5G-ND 530122B00162G-ND 501906B00000G-ND 553003B00000-ND 576403B00000G-ND 6032DG-ND 567103B00000-ND 6260B-MT5-ND 550202D00000G-ND HS141-ND 322805B00000G-ND 579003B00000G-ND 6381BG-ND 580200W00000G-ND 505303B00000G-ND 576203B00000G-ND 576303B00000G-ND 500203B00000G-ND 6380BG-ND 574204B03300G-ND 2332BG-ND 500303B00000G-ND 6382BG-ND HS265-ND 2262R-ND 520103B00000G-ND 6261B-MT5G-ND 2281B-ND 2333B-ND 519803B00000G-ND 568115B00000-ND 519703B00000G-ND 568300B00000-ND 568403B00000-ND 1116BG-ND 321127B00000-ND 2263R-ND 2334BG-ND 2292BG-ND 2321BG-ND B-375-120-62G-ND 2285B-ND 519903B00000G-ND 2268B-ND 2227B-ND 2286B-ND 1130B-ND 2283B-ND 2240BASSY-ND 782653B01000G-ND 2207/PR11BASSY-ND 2207/PR11B-2ASSYG-ND 622851F00000-ND
507302B00000G 577002B00000G 577102B00000G 573300D00010G 573300D00010G 573300D00010G 507002B00000G 577202B00000G 501200B00000G 504222B00000G 574902B03300G 576802B00000G 573300D00000G 593002B03400G 573100D00000G 573100D00010G 573100D00010G 508500B00000G 513102B02500G 531002B02500G 581002B00000 7109D/TRG 7109D/TRG 7109D/TRG 581002B02500G 7109DG 578622B03200G 7106DG 7021B-MTG 6396BG 6236BG 530002B02500G 534302B03553G 533002B02551G 322605B00000G 534202B03453G 533402B02552G 6400BG 529902B02500G 500403B00000G 375424B00034G 747652F00000G 574102B00000G 575002B00000G 575102B00000G 576802B03100G 576802B03900G 574902B00000G 7020BG 576802B04000G 577002B04000G 577102B04000G 592502B03400G 574502B00000G 591202B00000G 507102B00000G 530613B00000G 504102B00000G 577202B04000G 7173DG 577500B00000G 591302B02800G 530714B00000G 507222B00000G 575200B00000G 577404B00000G 573400D00010G 573400D00010G 573400D00010G 579302B00000G 574902B03700G 580200B00000G 580100B00000G 574502B03700G 576802B04100G 7136DG 593202B03500G 574502B03300G 501100B00000G 7020B-MTG 576602B00000G 7025B-MTG 6238B-MTG 6021BG 7141DG 7139DG 501303B00000G 531002B00000G 578305B00000G 6025DG 531102B02500G 501403B00000G 551002B00000G 6237BG 6043BG 531202B02500G 501603B00000G 530614B00000G 7023B-MTG 566010B03400G 529802B00000 563002B00000G 590102B03600G 581102B02500G 6222BG 529702B02500G 529801B02500G 574402B03200G 7019B-MTG 322400B00000G 593101B03600G 579103B00000G 326005B00000G 320205B00000G 581202B02500G 529901B02500G 6022BG 322505B00000G 6223BG 7022B-MTG 531302B02500G 323005B00000G 569003B00000G 563002D00000G 6230DG (COPPER) 530102B00150G 530402B00150G 533422B02552G 321527B00000G 342947 342950 637302F00000G 783502F00000G 576802B03700G 591202B04000G 574602B03700G 577304B00000G 523002B00000G 579402B00000G 574502B03200G 573902B00000G 7128DG 6030D(COPPER)G 542502D00000G 501503B00000G 542502B00000G 325705B00000G 6225B-MTG 529701B02500G 532602B02500G 530001B02500G 505403B00000G 533802B02500G 592201B03400G HF20G 530101B00150G 502403B00000 500103B00000G 591202B03700G 563202D00000G 7024B-MTG 531202B02100G HF35G 342940 342943 576802B00000 W/TAB038326 6230B-TTG 6025B-TTG 532702B02500G 342946 607602F00000G 622852F00000G 645002F00000G 654452F00000G 573902B04000G 506007B00000G 590302B03600G 7142DG 320105B00000G 342942 342941 615652F00000G 657152F00000G 342945 342948 663652F00000G 652452F00000G 631352F00000G 782452F00000G 782202F00000G 780102F00000G 780802F00000G 783452F00000G 780252F00000G 780752F00000G 780652F00000G 780152F00000G 780202F00000G 688552F00000G 622002F00000G 780302F00000G 610852F00000G 603402F00000G 605202F00000G 725452F00000 701652F00000G 627252F00000G 623352F00000G 531202B00000G TV-4G 513002B02500G 513201B02500G 529802B02500G 534202B02853G 6398BG 342949 633402F00000G 501000B00000G 592502B00000G 593002B00000G 576802B03300G 575400B00000G 575502B00000G 591202B03100G 591302B04000G 6273B 574802B00000G 574602B00000G 7019BG 574602B03300G 506902B00000G 574004B00000G 573400D00000G 507222B05300G 7024BG 578105B00000G 513002B00000 6271B 530714B05300G 530510B00000G 566902B00000G 592502B02800G 576012B00000G 7025BG 574402B00000G 578205B00000G 575300B00000G 578405B00000G 560200B00000G 579604B00000G 513101B00000 574902B04300G 7021BG 573902B03900G 335314B00000G 513001B02500G 7137DG 7023BG 563202B00000G 508600B00000G 7178DG 7140DG 7038BG 513202B02500G 581102B00000 566902B04000G 550302B00000 580500B00000G 513301B02500G 574204B00000G 529801B00000 580400B00000G 533002B02500G 513302B02500G 574802B03700G 6238BG 550402B00000 508700B00000G 335814B00000G 335714B00000G 7121DG 574102B03300G 7129DG 574802B03300G 531002B02100G 550102B00000 533201B02500G 533202B02500G 530001B00000 593202B03400G 6239BG 532602B00000 507002B05300G 529901B00000 529902B00000 578902B03200G 581101B02500G 531102B02100G 574102B03700G 6084BG 7106D/TRG 575703B00000G 529701B02100G 6396B-P2G 529801B02100G 311505B00000G 533101B02551G 513101B02500G 579704B00000G 335214B00000G 566010B00000G 552703B00000 533102B02551G 575603B00000G 580300B00000G 530001B02100G 581102B02100G 6399B-P2G 6399BG 533602B02500G 533701B02552G 6239B-MTG 552803B00000G 552844B00000 575803B00000G 533402B02500G 7138DG 529902B02100G 533702B02552G 533722B02552G 6038BG 533202B02551G 594302B02853G 6038DG 7148DG 576602D00000G 566102B00000G 6232B-MTG 523002D00000G 7021B-MT6G 575002D00000G 530614B05300G 335314B00032G 6045B 581002B02100G 529901B02100G 592902B03400G 335214B00032G 2328BG 311505A00000G 584000B03300G 533502B02552G 530101B00100G 326005R00000G 502203B00000 325705R00000G 575903B00000G 533302B02551G 580100W00000G 530801B05150G 566010B02800G 6109BG 532802B02500G 7130DG 530802B05100G 530400B00100G 533522B02552G 2342B 501806B00000G 508222B00000 6000DG 506003B01300 530801B05100G 502006B00000G 501706B00000G 560700B00000 6400B-P2G 6263B-MT5G 530122B00162G 501906B00000G 553003B00000 576403B00000G 6032DG 567103B00000 6260B-MT5 550202D00000G 502303B00000 322805B00000G 579003B00000G 6381BG 580200W00000G 505303B00000G 576203B00000G 576303B00000G 500203B00000G 6380BG 574204B03300G 2332BG 500303B00000G 6382BG 500503B00000G 2262R 520103B00000G 6261B-MT5G 2281B 2333B 519803B00000G 568115B00000 519703B00000G 568300B00000 568403B00000 1116BG 321127B00000 2263R 2334BG 2292BG 2321BG B-375-120-62G 2285B 519903B00000G 2268B 2227B 2286B 1130B 2283B 2240B ASSY 782653B01000G 2207/PR11B ASSY 2207/PR11B-2 ASSYG 622851F000
