About the Capacitors category
Capacitior Product Support, FAQs, and other topics.
I need a replacement for
A3
100
35T
Hi,
Welcome to the Digikey tech forum. Can you provide a photo of the capacitor ?
Hi,
See image below. The caps in the packaging on the left are what the customer purchased, and the two on the table are what was originally installed in this board and accidentally got pulled out when the port connector at the bottom took a hit.
First question is, are the caps that the customer purchased correct? If not, then I would need a link to order the correct ones from Digikey.
Second question is, do you guys happen to sell the black port connectors to replace that damaged one, or are they a custom part?
Thanks!
I was going to start a new topic but dont see how to?
I am looking for input into filter capacitors for a Fisher KX-200 amplifier thanks!
Go here Latest Passives/Capacitors topics - DigiKey TechForum - An Electronic Component and Engineering Solution Forum and hit the New Topic button.
We will need the capacitance, voltage and physical size for the capacitors you’re looking for.
