I commented chvt in the service. I found chvt command doesn’t switch: for example:
$tty
/dev/ttyS0
$sudo chvt 6
/dev/ttyS0
And it is not connected to vt, probably.
Hi Robert,
I gave up. Using other ways to handle.
? probably is created when I added --autologin at the end. If just -a USERNAME, and remove -o ’ - p \u ’ stuff. The tty with ? disppears.
Also systemd is a mult-users & multi-threads system, so it is not good place for holding some process until user input. So I think I don’t need a dialog or user input for things I need to install for bare boards.
