A recent question that came in was regarding Adjustable Power Resistors and how the power rating is affected by the change in resistance. So does the change in resistance cause a change in power? The short answer, yes. Resistors are passive elements that introduce resistance to the flow of electric current in a circuit. Ohm’s power law states P=R·I²
Lets take a look at Vishay part AVT10006E1K000KE. This is a 1.0K OHM 100W Adjustable Power Resistor.
Now assuming your current will remain constant in your circuit, the power of the resistor is directly proportional to the resistance given to the resistor via the adjustable band.
For simplicity lets assume you have a current of 0.316A in your circuit, then:
- If you set the resistor to 1.0K Ohms, you’ll obtain 1.0K Ohm · 3162A ~ 100W (Max Resistance would be Max Rated Power)
- If you set the resistor to 500 Ohms, you’ll obtain 500 Ohm · 3162A ~ 50W
- If you set the resistor to 250 Ohms, you’ll obtain 250 Ohm · 3162A ~ 25W
Applicable Part Numbers
AVT02506E50R00KE AVT02506E100R0KE AVT02506E5R000KE AVT02506E10R00KE AVT05006E1R000KE AVT05006E5R000KE AVT05006E50R00KE AVT05006E100R0KE AVT05006E1K000KE AVT10006E1K000KE D25K10RE AVE030020ER120KE AVE030020E8R00KE AVT20020E5R000KE AVT20020E2R000KE AVT20020E250R0KE AVE030020ER800KE AVE030020ER200KE AVT20020E1R000KE D225K50RE AVT02506E3R000KE AVT05006E3R000KE AVT10006E250R0KE AVT02506E1R000KE AVT02506E25R00KE AVT05006E10R00KE AVT05006E2R000KE AVT05006E500R0KE AVT05006E25R00KE AVT10006E10R00KE AVT10006E100R0KE AVT10006E1R000KE AVE030020E16R0KE AVE030020E1R00KE AVE030020E1R60KE AVT20020E3R000KE AVT20020E50R00KE AVT20020E1K000KE AVT20020E100R0KE AVT20020E500R0KE RSSD25168A10R0JB06 AVT02506E500R0KE D50K25RE D50K1K0E D50K50RE D50K1R0E AVT20020E200R0KE AVE030020ER160KE D100K1K0E D100K250E D100K100E D100K10RE D100K2R0E RSSD20117A22R0JB15 RSSD20117A10R0JB15 RSSD20117A4R70KB15 D100K1R0E D225K100E D225K1K0E D225K500E D225K150E D225K250E D225K10RE RSSD25168A1000JB06 RSSD25168A22R0JB06 D225K2R0E RSSD30250A47R0JB06 D100K50RE RSSD20117A1000JB15 E300K1R0E D12K75R D175K25RE D500J500E AVT10006E50R00KE AVT10006E2R000KE AVE030020E20R0KE AVT20020E10R00KE AVT20020E25R00KE AVE030020ER100KE AVT02506E250R0KE D25K250E D25K3R0E D25K500E D50K10RE AVT20020E150R0KE D225K25RE D225K5R0E D25K5R0E D25K25RE D25K50RE D50K100E RSSD20117A47R0JB15 D225K1R0E AVT10006E6R000KE D25K100E D12K100E D12K10RE D12K150E D12K15RE D12K200E D12K20RE D12K25RE D12K50RE D12K75RE D12K7R5E D12K250 D12K350 D12K500 D12K600 D12K750 D25K150E D25K15RE D25K200E D25K20RE D25K300E D25K400E D25K75RE D25K7R5E D25K12KE D25K15KE D25K1K0 D25K1K25 D25K1K5 D25K20KE D25K25KE D25K2K0 D25K2K25 D25K2K5 D25K750 D12K1R0E D12K2R0E D12K3R0E D12K5R0E D25K1R0E D12K250E D12K300E D12K350E D12K400E D12K500E D12K600E D12K750E D25K1K0E D25K1K25E D25K1K5E D25K2K0E D25K2K25E D25K2K5E D25K3K0E D25K3K5E D25K4K0E D25K4K5E D25K750E D25K800E D12K1K0 D12K2K0 D12K2K5 D12K3K0 D12K3K5 D25K2R0E D12K10K D12K7K0 D12K8K0 D25K5K0 D25K7K0 D25K7K5 D12K1K0E D12K1K25E D12K1K5E D12K2K0E D12K2K25E D12K2K5E D12K3K0E D12K3K5E D12K4K0E D12K4K5E D12K800E D12K100 D12K10R D12K150 D12K15R D12K20R D12K25R D12K7R5 D12K10KE D12K5K0E D12K6K0E D12K7K0E D12K7K5E D12K8K0E D12K8K5E D12K9K0E D25K10R D25K100 D25K25R D25K250 D25K3R0 D25K5R0 D25K50R D25K500 D25K150 D25K15R D25K200 D25K20R D25K300 D25K400 D25K75R D25K7R5 D25K12K D25K15K D25K20K D25K25K D25K10KE D25K5K0E D25K6K0E D25K7K0E D25K7K5E D25K8K0E D25K9K0E D12K1R0 D12K2R0 D12K3R0 D12K5R0 D25K1R0 D25K2R0 D50K1K25E D50K1K5E D50K2K0E D50K2K25E D50K2K5E D50K3K0E D50K3K5E D50K4K0E D50K500E D50K150E D50K200E D50K250E D50K300E D50K400E D50K750E D50K75RE D50K800E D50K25KE D50K10KE D50K12KE D50K15KE D50K20KE D50K30KE D50K40KE D50K4K5E D50K50KE D50K5K0E D50K6K0E D50K7K0E D50K7K5E D50K8K0E D50K9K0E D50K10R D50K100 D50K25R D50K50R D50K500 D50K150 D50K200 D50K250 D50K300 D50K400 D50K750 D50K75R D50K800 AVT16020E100R0KE D50K100KE D50K60KE D50K80KE D50K5R0E D50K1K0 D50K1K5 D50K2K0 D50K2K5 D50K3K0 D50K3K5 D50K4R0E D50K2R0E D50K3R0E D50K10K D50K15K D50K25K D50K50K D50K5K0 D50K7K5 D50K100K D50K80K RSSD10X50A10R0JS06 D50K5R0 D50K4R0 D50K1R0 D50K2R0 D50K3R0 D100K10KE D100K15KE D100K20KE D100K25KE D100K30KE D100K40KE D75K100E D75K10KE D75K12KE D75K15KE D75K1K0E D75K1K25E D75K1K5E D75K200E D75K20KE D75K250E D75K25KE D75K2K0E D75K2K25E D75K2K5E D75K300E D75K3K0E D75K3K5E D75K400E D75K4K0E D75K4K5E D75K500E D75K5K0E D75K6K0E D75K750E D75K7K0E D75K7K5E D75K800E D75K8K0E D75K9K0E D75K10RE D75K15RE D75K25RE D75K50RE D100K1K5E D100K25RE D100K2K5E D100K500E D100K5K0E D100K10K D100K20K D75K30KE D75K35KE D75K40KE D75K45KE D75K50KE D75K60KE D100K100KE D100K50KE D100K75KE D75K1K0 D75K20K D75K250 D75K2K0 D75K300 D75K3K5 D75K400 D75K500 D75K8K0 D75K100KE D75K80KE D75K10R D75K15R D75K50R D100K1K0 D100K100 D100K250 D100K50R D100K1K5 D100K25R D100K2K5 D100K500 D100K5K0 D100K100K D100K50K D100K3R0E D100K4R0E D100K5R0E D75K1R0E D75K2R0E D75K3R0E D75K4R0E D75K5R0E D75K2R0 D100K10R D100K2R0 D100K3R0 D100K4R0 D100K5R0 D100K1R0 D175K10KE D175K15KE D175K20KE D175K25KE D175K30KE D175K1K0E D175K1K5E D175K2K5E D175K5K0E D175K100E D175K250E D175K500E D175K10K D175K20K D175K40KE D175K50KE D175K75KE D225K200E D225K10KE D225K15KE D225K1K5E D225K20KE D225K25KE D225K2K5E D225K30KE D225K40KE D225K5K0E D175K1K0 D175K2K5 D175K5K0 D175K100 D175K250 D175K500 D175K100KE D225K1K0 D225K100 D225K150 D225K200 D225K250 D225K500 D225K10K D225K1K5 D225K25K D225K2K5 D225K5K0 D225K100KE D225K50KE D225K75KE D175K10RE D175K50RE D175K100K D225K100K D225K50K D175K10R D175K25R D175K50R D175K2R0E D175K3R0E D175K4R0E D175K5R0E D225K10R D225K25R D225K50R D175K2R0 D175K3R0 D175K5R0 E300K10RE E300K12RE E300K16RE E300K20RE D225K4R0E E300K5R0E E300K6R3E E300K8R0E D175K1R0E E300K2R0E E300K2R5E E300K3R1E E300K4R0E E300K10R E300K16R E300K20R D225K5R0 D225K4R0 E300K1R2E E300K1R6E D225K3R0E E300K2R0 E300K2R5 E300K3R1 E300K4R0 E300K5R0 E300K6R3 E300K8R0 D175K1R0 RSSD25168A2200JB06 RSSD25168A47R0JB06 E300K1R0 E300K1R2 E300K1R6 E300KR40E E300KR50E E300KR63E E300KR80E D225K2R0 E300KR16E E300KR20E E300KR25E AVT25-50-ND AVT25-100-ND AVT25-5.0-ND AVT25-10-ND AVT50-1.0-ND AVT50-5.0-ND AVT50-50-ND AVT50-100-ND AVT50-1.0K-ND AVT100-1.0K-ND D25K10RE-ND AVE300-.12-ND AVE300-8.0-ND AVT20020E5R000KE-ND AVT20020E2R000KE-ND AVT20020E250R0KE-ND AVE300-.80-ND AVE300-.20-ND AVT20020E1R000KE-ND D225K50RE-ND AVT25-3.0-ND AVT50-3.0-ND AVT100-250-ND AVT25-1.0-ND AVT25-25-ND AVT50-10-ND AVT50-2.0-ND AVT50-500-ND AVT50-25-ND AVT100-10-ND AVT100-100-ND AVT100-1.0-ND AVE300-16-ND AVE300-1.0-ND AVE300-1.6-ND
