ALTERNATIVE CHECK
PLEASE CONFIRM IF P/N MLG1005S91NJTD25 IS OKAY TO USE AS AN ALTERNATIVE FOR MLG1005S91NJT000
Hello malavb,
The only difference in the part number is the 000 & D25 suffixes. The datasheet states that is an internal code for TDK, so it would not change the function of the part. For functionality, they would be identical.
Please check the datasheet for compatibility to your application.
