Alternative Connector for CA02COM-E10SL-3P-B
Can article ’ CA02COM-E10SL-3P-B ', delivered by DigiKey, being used as 100% replacement for below connector? Are the specs identical so the client can also use their original powercable with the female connector on DigiKey’s connector CA02COM-E10SL-3P-B ?
The data sheet of the connector we need to replace:
EPIC Connectors CM13102A10SL-3P. Datasheet | View EPIC Connectors CM13102A10SL-3P. Datasheets - Octopart.
CM13102A10SL-3P ( = a NON DIGIKEY item and can’t be delivered anymore)
Above picture: the connector we need to replace.
Below the picture of the DigiKey connector CA02COM-E10SL-3P-B .
I am looking forward to the reply.
With best regards,
Patrick
Hello @patrickalbers, thank you for your question.
The ITT Cannon CA02COM-E10SL-3P-B should be compatible with the EPIC CM13102A10SL-3P:
  • Same 10SL-3 pin layout (Cannon datasheet page 6, EPIC datasheet page 11)
  • Same mounting dimensions (Cannon page 20, EPIC page 46, 10SL row)
  • Same bayonet coupling, so your existing cable will fit (Cannon page 2)
CA02COM-E10SL-3P-B-ND | CA02COM-E10SL-3P-B
Datasheet
Please review the datasheets to ensure the alternative will work for your application.
