Alternative for 5WD27 from NTE Electronics
The 5WD27 wirewound resistor from NTE Electronics has been rendered obsolete. We offer the below product from TE Connectivity Passive Product as our closest similar alternative. However, it only comes in radial type not axial. For axial options I have provided a link to similar options but be aware they have a slightly different operating temperature range. Please review the datasheets to ensure the alternative will work for your application.
MFR PART # SQMW5R27J
DIGIKEY PART # A137379-ND
MANUFACTURER TE Connectivity Passive Product
DESCRIPTION 270 mOhms ±5% 5W Through Hole Resistor Radial Cement Coated, Flame Proof, Moisture Resistant, Safety Wirewound
DATASHEET Click Here
For Axial Options:
270 mOhms 5W Axial Through Hole Resistors | Electronic Components Distributor DigiKey
5WD27.pdf (498.5 KB)
