We do not currently carry the CFR-25GT-52-2M2 resistor from Yageo. However, we do carry a similar resistor CFR-25JT-52-2M2. According to the datasheet, the difference between the G and J suffixes is the G has a 2% tolerance and the J has a 5% tolerance. Please review the datasheets and make sure it will work for your application.
| MFR PART # | CFR-25JT-52-2M2 |
| DIGI-KEY PART # | 13-CFR-25JT-52-2M2CT-ND - Cut Tape (CT) |
| MANUFACTURER | YAGEO |
| DESCRIPTION | 2.2 MOhms ±5% 0.25W, 1/4W Through Hole Resistor Axial Carbon Film |
YAGEO_CFR_datasheet_2023v2-3388672.pdf (943.4 KB)
