Alternative for WR04X40R2FTL from Walsin Technology Corporation
We do have the WR04X40R2FTL resistor from Walsin Technology Corporation available to order, however manufacturer lead times and minimum order quantities apply. For an alternative that is readily available please consider the following resistor from Stackpole Electronics Inc. Please review the datasheets to ensure the alternative will work for your application.
MFR PART # RMCF0402FT40R2
DIGIKEY PART # RMCF0402FT40R2TR-ND - Tape & Reel (TR)
MANUFACTURER Stackpole Electronics Inc
DESCRIPTION 40.2 Ohms ±1% 0.063W, 1/16W Chip Resistor 0402 (1005 Metric) Automotive AEC-Q200 Thick Film
DATASHEET Click Here
Side by Side Comparison
Please note that the reverse is not true, the RMCF0402FT40R2 is AEC-Q200 rated and can replace the WR04X40R2FTL but the WR04X40R2FTL should not be used to replace the RMCF0402FT40R2 as it is not rated for automotive use.
