The GB0503PFV1-8 B1837 is obsolete but we do carry a few similar options below. These are not drop-in replacements so check the datasheet to ensure it will work for your application.
MFR PART # | DB0301005H1A-2T0 |
DIGIKEY PART # | 345-DB0301005H1A-2T0-ND |
MANUFACTURER | Wakefield-Vette |
DESCRIPTION | Fan Blower 5VDC Square - 30mm L x 30mm H Ball 1.1 CFM (0.031m³/min) 2 Wire Leads |
DATASHEET | Click Here |
MFR PART # | BFB0305HHA-C |
DIGIKEY PART # | 603-BFB0305HHA-C-ND |
MANUFACTURER | Delta Electronics |
DESCRIPTION | Fan Blower 5VDC Square - 30mm L x 30mm H Ball 1.7 CFM (0.046m³/min) 2 Wire Leads |
MFR PART # | BFB0305HA-C |
DIGIKEY PART # | 603-2111-ND |
DESCRIPTION | Fan Blower 5VDC Square - 30mm L x 30mm H Ball 1.5 CFM (0.042m³/min) 2 Wire Leads |
