I need to get a quote or replacement information for the Arcata Electronic Driver: SLP 50-I1000 120-277 WD1P
adriana.trevino
Thank you for contacting DigiKey I was not able to find that number I found numbers that were close to try and get some specs . Take a look at part number 1866-5583-ND, check data sheets to see if this will work for you.
Thanks Craig
