The ARM University Program has teamed up with DigiKey to ship the complete ARM-mbed™ Lab-in-a-Box hardware kit centered around the STMicroelectronics NUCLEO-F401RE board. Academics who want to adopt the kit in their teaching can request a sample donation from the ARM University Program website.
The whole hardware kit needed for this product can be purchased from DigiKey.com, however will not find a kit on the DigiKey website using the standard part search. This is actually a BOM that was created and you can add the kit parts to your cart by clicking on the link below.
Here is a list of components in the kit
| Component | Description | Manufacturer | Part Number | Manufacturer Part Number | QTY |
| Board | Board NUCLEO STM32F4 Series | STMicroelectronics | 497-14360-ND | NUCLEO-F401RE | 1 |
| Power Cord | USB A to Mini B Connector | Qualtek | Q362-ND | 3021003-03 | 1 |
| RGB LED | 5mm 3 Color RGB LED (Common Cathode) | Kingbright | 754-1492-ND | WP154A4SUREQBFZGW | 1 |
| Character LCD | 16 x 2 character LCD display module | Newhaven Display Intl | NHD-0216HZ-FSW-FBW-33V3C-ND | NHD-0216HZ-FSW-FBW-33V3C | 1 |
| Button | Push button switch breadboard friendly | E-Switch | EG4788-ND | KS-00Q-01 | 4 |
| Potentiometer | Linear 10kΩ rotary potentiometer 9mm square | Bourns Inc. | 3310Y-001-103L-ND | 3310Y-001-103L | 2 |
| Buzzer | Buzzer piezo 4Khz 12.2mm | TDK Corporation | 445-2525-1-ND | PS1240P02BT | 1 |
| Shift Register | 74HC595N IC 8-bit shift register 16-dip | Texas Instruments | 296-1600-5-ND | SN74HC595N | 1 |
| Temperature Sensor | DS1631 IC digital thermometer 8-DIP | Maxim Integrated | DS1631+-ND | DS1631+ | 1 |
| Resistors | Through hole resisters for the RGB LED | Stackpole Electronics Inc | CF14JT220RCT-ND | CF14JT220R | 3 |
| Resistors | Through hole resisters for the I2C lines | Stackpole Electronics Inc | CF14JT1K00CT-ND | CF14JT1K00 | 2 |
| Resistors | Through hole resisters for the buttons | Stackpole Electronics Inc | CF14JT10K0CT-ND | CF14JT10K0 | 4 |
| Breadboard | Breadboard solderless (81.3mm x 52.8mm) | Bud Industries | 377-2094-ND | BB-32621 | 1 |
| Wires | Wire set 140pc for breadboard | Twin Industries | 438-1049-ND | TW-E012-000 | 1 |
*For ordering multiple educational kits please contact MultiKitOrdering@digikey.com
