Automatic switching between debugger and power measurements
If you’re testing your device’s power consumption but always get frustrated when you have to disconnect and reconnect the debugger to flash new software manually, I have a treat for you! Switching is crucial for obtaining accurate data when evaluating your firmware’s impact on power consumption.
That’s why we’ve developed a switchboard prototype to automate this repetitive task. With the help of Otii’s GPOs, you can automatically control the connect/disconnect of your debugger or USB connection via a simple script (using Otii Automation Toolbox). You can build it yourself; check out the details here and our Github.
