CR126-ND this item says it is obsolete. My customers original fan is a Muffin XL MX2A3 part number 028316. Do you have a replacement?
This my first time on the forum. Do you answer my question or how do I get an answer?
I’m looking for an alternative as we speak, and some of my colleagues probably are, too.
We should have an answer very soon.
Maybe? 19030519A Comair Rotron | Fans, Thermal Management | DigiKey
Main difference, is: Sleeve → Ball bearings…
Regards,
I’m finding more or less the same results as Robert (posted above). Either [ CR554-ND ] or [ CR553-ND ] with the main difference between those two being the agency approvals. Also, both of these have wire leads instead of the unwired terminals of the original. I didn’t see any other options that were active (not obsolete).
