[quote=“h.carter, post:1, topic:31221, full:true”]
Is there a way to change the Background color of the main window
I have a wiring harness with some white wires and would like to see them as white against a contrasting background
You can refer this hereThere is no way to change a text box background color
To change the background color of the main window in your software application, explore customization options within the settings menu. Look for themes, appearance, or display preferences that allow you to modify the background color. Navigate to the preferences or options menu, and check for specific settings related to the application’s appearance. If available, contextual menus accessed by right-clicking in different areas of the main window might also offer customization options. Refer to the user manual or help section of the software for detailed guidance on adjusting the background color. Keep in mind that the ability to customize background colors varies between different software applications.
thank you
