If you find yourself concerned about the baking conditions for the MachXO3 Field Programmable Gate Array (FPGA) LCMXO3LF-9400C-6BG256C from Lattice Semiconductor Corporation, then peak soldering temperature should be taken into consideration.
Reflow soldering is a process in which a solder paste (a sticky mixture of powdered solder and flux) is used to temporarily attach anywhere from one to thousands of tiny electrical components to their contact pads, after which the entire assembly is subjected to controlled heat.
As per the manufacturer’s datasheet, the peak reflow temperature for this device can vary from 220°C to 260°C for the FPGA.
Reference: Page 9 in the datasheet attached below:
FPGA-TN-02041-4-8-Solder-Reflow-Guide-for-Surface-Mount-Devices.pdf (399.4 KB)
Applicable Part Numbers
| DK Part # | Mfr Part # | |
| 220-2235-2-ND,220-2235-1-ND,220-2235-6-ND | LCMXO3L-1300E-5UWG36CTR1K | |
| 220-2222-2-ND,220-2222-1-ND,220-2222-6-ND | LCMXO3LF-1300E-5UWG36ITR1K | |
| 220-2092-ND | LCMXO3LF-640E-5MG121I | |
| 220-2156-2-ND,220-2156-1-ND,220-2156-6-ND | LCMXO3LF-2100E-5UWG49CTR1K | |
| 220-2223-2-ND,220-2223-1-ND,220-2223-6-ND | LCMXO3LF-2100E-5UWG49ITR1K | |
| 220-2143-2-ND,220-2143-1-ND,220-2143-6-ND | LCMXO3LF-4300E-5UWG81CTR1K | |
| 220-2093-ND | LCMXO3LF-4300E-5MG121C | |
| 220-2001-ND | LCMXO3LF-1300C-5BG256I | |
| 220-2005-ND | LCMXO3LF-2100C-5BG256I | |
| 220-2009-ND | LCMXO3LF-4300C-5BG256I | |
| 220-2013-ND | LCMXO3LF-6900C-5BG256I | |
| 220-2015-ND | LCMXO3LF-6900C-6BG256I | |
| 220-2158-ND | LCMXO3LF-9400C-6BG256C | |
| 220-2231-2-ND,220-2231-1-ND,220-2231-6-ND | LCMXO3LF-1300E-5UWG36CTR1K | |
| 220-2181-ND | LCMXO3L-4300E-5MG121C | |
| LCMXO3LF-4300E-5MG121I-ND | LCMXO3LF-4300E-5MG121I | |
| 220-2000-ND | LCMXO3LF-1300C-5BG256C | |
| LCMXO3LF-4300E-6MG121I-ND | LCMXO3LF-4300E-6MG121I | |
| 220-1887-ND | LCMXO3L-6900C-6BG256C | |
| 220-2175-ND | LCMXO3LF-6900E-6MG256C | |
| LCMXO3LF-9400C-5BG256C-ND | LCMXO3LF-9400C-5BG256C | |
| 220-2168-ND | LCMXO3LF-9400E-6BG256I | |
| 220-2227-2-ND,220-2227-1-ND,220-2227-6-ND | LCMXO3L-4300E-5UWG81CTR1K | |
| 220-2237-2-ND,220-2237-1-ND,220-2237-6-ND | LCMXO3L-4300E-5UWG81ITR1K | |
| 220-2157-2-ND,220-2157-1-ND,220-2157-6-ND | LCMXO3LF-4300E-5UWG81ITR1K | |
| 220-1920-ND | LCMXO3L-1300C-5BG256C | |
| 220-2180-ND | LCMXO3LF-2100E-6MG256C | |
| 220-1940-ND | LCMXO3L-4300C-5BG324C | |
| 220-1885-ND | LCMXO3L-4300C-6BG256I | |
| 220-1980-ND | LCMXO3LF-4300C-5BG400C | |
| 220-2169-ND | LCMXO3LF-9400E-6BG484I | |
| 220-LCMXO3L-1300E-5UWG36ITR-ND,220-LCMXO3L-1300E-5UWG36ITRCT-ND,220-LCMXO3L-1300E-5UWG36ITRDKR-ND | LCMXO3L-1300E-5UWG36ITR | |
| 220-2220-2-ND,220-2220-1-ND,220-2220-6-ND | LCMXO3L-2100E-5UWG49CTR1K | |
| 220-LCMXO3LF-1300E-5UWG36ITR-ND,220-LCMXO3LF-1300E-5UWG36ITRCT-ND,220-LCMXO3LF-1300E-5UWG36ITRDKR-ND | LCMXO3LF-1300E-5UWG36ITR | |
| LCMXO3LF-1300E-5MG121I-ND | LCMXO3LF-1300E-5MG121I | |
| 220-LCMXO3LF-2100E-5UWG49ITR-ND,220-LCMXO3LF-2100E-5UWG49ITRCT-ND,220-LCMXO3LF-2100E-5UWG49ITRDKR-ND | LCMXO3LF-2100E-5UWG49ITR | |
| LCMXO3LF-2100E-5MG256C-ND | LCMXO3LF-2100E-5MG256C | |
| LCMXO3LF-4300E-5MG256C-ND | LCMXO3LF-4300E-5MG256C | |
| 220-2004-ND | LCMXO3LF-2100C-5BG256C | |
| 220-2003-ND | LCMXO3LF-1300C-6BG256I | |
| LCMXO3LF-6900E-6MG256I-ND | LCMXO3LF-6900E-6MG256I | |
| 220-2011-ND | LCMXO3LF-4300C-6BG256I | |
| 220-2024-ND | LCMXO3LF-6900C-5BG324C | |
| 220-2026-ND | LCMXO3LF-6900C-6BG324C | |
| LCMXO3LF-4300E-6MG121C-ND | LCMXO3LF-4300E-6MG121C | |
| 220-2167-ND | LCMXO3LF-9400E-5BG256I | |
| 220-2012-ND | LCMXO3LF-6900C-5BG256C | |
| 220-1984-ND | LCMXO3LF-6900C-5BG400C | |
| 220-1987-ND | LCMXO3LF-6900C-6BG400I | |
| 220-1982-ND | LCMXO3LF-4300C-6BG400C | |
| 220-1981-ND | LCMXO3LF-4300C-5BG400I | |
| 220-2014-ND | LCMXO3LF-6900C-6BG256C | |
| 220-2017-ND | LCMXO3LF-2100C-5BG324I | |
| 220-2174-ND | LCMXO3LF-6900E-5MG256I | |
| 220-1983-ND | LCMXO3LF-4300C-6BG400I | |
| 220-2022-ND | LCMXO3LF-4300C-6BG324C | |
| LCMXO3L-9400C-5BG400I-ND | LCMXO3L-9400C-5BG400I | |
| LCMXO3L-1300E-5UWG36CTR-ND | LCMXO3L-1300E-5UWG36CTR | |
| LCMXO3LF-1300E-5UWG36CTR-ND | LCMXO3LF-1300E-5UWG36CTR | |
| 220-2236-2-ND,220-2236-1-ND,220-2236-6-ND | LCMXO3L-1300E-5UWG36ITR1K | |
| LCMXO3L-2100E-5UWG49CTR-ND | LCMXO3L-2100E-5UWG49CTR | |
| LCMXO3L-640E-5MG121C-ND | LCMXO3L-640E-5MG121C | |
| LCMXO3L-2100E-5UWG49ITR-ND | LCMXO3L-2100E-5UWG49ITR | |
| LCMXO3L-640E-5MG121I-ND | LCMXO3L-640E-5MG121I | |
| LCMXO3L-640E-6MG121C-ND | LCMXO3L-640E-6MG121C | |
| LCMXO3LF-2100E-5UWG49CTR-ND | LCMXO3LF-2100E-5UWG49CTR | |
| LCMXO3L-4300E-5UWG81CTR-ND | LCMXO3L-4300E-5UWG81CTR | |
| LCMXO3L-640E-6MG121I-ND | LCMXO3L-640E-6MG121I | |
| LCMXO3LF-640E-5MG121C-ND | LCMXO3LF-640E-5MG121C | |
| 220-2221-2-ND,220-2221-1-ND,220-2221-6-ND | LCMXO3L-2100E-5UWG49ITR1K | |
| LCMXO3L-1300E-5MG121C-ND | LCMXO3L-1300E-5MG121C | |
| LCMXO3LF-640E-6MG121C-ND | LCMXO3LF-640E-6MG121C | |
| LCMXO3L-4300E-5UWG81ITR-ND | LCMXO3L-4300E-5UWG81ITR | |
| LCMXO3L-1300E-5MG121I-ND | LCMXO3L-1300E-5MG121I | |
| LCMXO3L-1300E-6MG121C-ND | LCMXO3L-1300E-6MG121C | |
| LCMXO3LF-4300E-5UWG81CTR-ND | LCMXO3LF-4300E-5UWG81CTR | |
| LCMXO3LF-640E-6MG121I-ND | LCMXO3LF-640E-6MG121I | |
| LCMXO3LF-1300E-5MG121C-ND | LCMXO3LF-1300E-5MG121C | |
| LCMXO3L-1300E-6MG121I-ND | LCMXO3L-1300E-6MG121I | |
| LCMXO3L-2100E-5MG121C-ND | LCMXO3L-2100E-5MG121C | |
| LCMXO3LF-4300E-5UWG81ITR-ND | LCMXO3LF-4300E-5UWG81ITR | |
| LCMXO3L-1300E-5MG256C-ND | LCMXO3L-1300E-5MG256C | |
| LCMXO3LF-1300E-6MG121C-ND | LCMXO3LF-1300E-6MG121C | |
| LCMXO3L-2100E-5MG121I-ND | LCMXO3L-2100E-5MG121I | |
| LCMXO3L-2100E-6MG121C-ND | LCMXO3L-2100E-6MG121C | |
| LCMXO3L-1300E-5MG256I-ND | LCMXO3L-1300E-5MG256I | |
| LCMXO3L-1300E-6MG256C-ND | LCMXO3L-1300E-6MG256C | |
| LCMXO3LF-1300E-6MG121I-ND | LCMXO3LF-1300E-6MG121I | |
| LCMXO3L-2100E-6MG121I-ND | LCMXO3L-2100E-6MG121I | |
| LCMXO3LF-2100E-5MG121C-ND | LCMXO3LF-2100E-5MG121C | |
| LCMXO3L-2100E-5MG256C-ND | LCMXO3L-2100E-5MG256C | |
| LCMXO3LF-1300E-5MG256C-ND | LCMXO3LF-1300E-5MG256C | |
| LCMXO3L-1300E-6MG256I-ND | LCMXO3L-1300E-6MG256I | |
| LCMXO3LF-2100E-5MG121I-ND | LCMXO3LF-2100E-5MG121I | |
| LCMXO3LF-2100E-6MG121C-ND | LCMXO3LF-2100E-6MG121C | |
| LCMXO3L-4300E-5MG121I-ND | LCMXO3L-4300E-5MG121I | |
| LCMXO3L-4300E-6MG121C-ND | LCMXO3L-4300E-6MG121C | |
| LCMXO3L-2100E-5MG256I-ND | LCMXO3L-2100E-5MG256I | |
| LCMXO3L-2100E-5MG324C-ND | LCMXO3L-2100E-5MG324C | |
| LCMXO3L-2100E-6MG256C-ND | LCMXO3L-2100E-6MG256C | |
| LCMXO3LF-1300E-5MG256I-ND | LCMXO3LF-1300E-5MG256I | |
| LCMXO3LF-1300E-6MG256C-ND | LCMXO3LF-1300E-6MG256C | |
| LCMXO3LF-2100E-6MG121I-ND | LCMXO3LF-2100E-6MG121I | |
| LCMXO3L-4300E-6MG121I-ND | LCMXO3L-4300E-6MG121I | |
| LCMXO3L-4300E-5MG256C-ND | LCMXO3L-4300E-5MG256C | |
| LCMXO3L-2100E-5MG324I-ND | LCMXO3L-2100E-5MG324I | |
| LCMXO3L-2100E-6MG256I-ND | LCMXO3L-2100E-6MG256I | |
| LCMXO3L-2100E-6MG324C-ND | LCMXO3L-2100E-6MG324C | |
| LCMXO3LF-1300E-6MG256I-ND | LCMXO3LF-1300E-6MG256I | |
| 220-1921-ND | LCMXO3L-1300C-5BG256I | |
| 220-1922-ND | LCMXO3L-1300C-6BG256C | |
| LCMXO3L-4300E-5MG256I-ND | LCMXO3L-4300E-5MG256I | |
| LCMXO3L-4300E-6MG256C-ND | LCMXO3L-4300E-6MG256C | |
| LCMXO3LF-2100E-5MG256I-ND | LCMXO3LF-2100E-5MG256I | |
| LCMXO3LF-2100E-5MG324C-ND | LCMXO3LF-2100E-5MG324C | |
| LCMXO3L-2100E-6MG324I-ND | LCMXO3L-2100E-6MG324I | |
| 220-1878-ND | LCMXO3L-2100C-5BG256C | |
| LCMXO3L-4300E-5MG324C-ND | LCMXO3L-4300E-5MG324C | |
| LCMXO3L-6900E-5MG256C-ND | LCMXO3L-6900E-5MG256C | |
| 220-1923-ND | LCMXO3L-1300C-6BG256I | |
| 220-1936-ND | LCMXO3L-2100C-5BG324C | |
| LCMXO3L-4300E-6MG256I-ND | LCMXO3L-4300E-6MG256I | |
| LCMXO3LF-2100E-5MG324I-ND | LCMXO3LF-2100E-5MG324I | |
| LCMXO3LF-2100E-6MG256I-ND | LCMXO3LF-2100E-6MG256I | |
| LCMXO3LF-2100E-6MG324C-ND | LCMXO3LF-2100E-6MG324C | |
| 220-1882-ND | LCMXO3L-4300C-5BG256C | |
| 220-1879-ND | LCMXO3L-2100C-6BG256C | |
| 220-1880-ND | LCMXO3L-2100C-5BG256I | |
| LCMXO3L-4300E-5MG324I-ND | LCMXO3L-4300E-5MG324I | |
| LCMXO3L-4300E-6MG324C-ND | LCMXO3L-4300E-6MG324C | |
| 220-2002-ND | LCMXO3LF-1300C-6BG256C | |
| LCMXO3L-6900E-5MG256I-ND | LCMXO3L-6900E-5MG256I | |
| LCMXO3L-6900E-6MG256C-ND | LCMXO3L-6900E-6MG256C | |
| LCMXO3LF-2100E-6MG324I-ND | LCMXO3LF-2100E-6MG324I | |
| LCMXO3LF-4300E-5MG256I-ND | LCMXO3LF-4300E-5MG256I | |
| LCMXO3LF-4300E-6MG256C-ND | LCMXO3LF-4300E-6MG256C | |
| 220-1883-ND | LCMXO3L-4300C-6BG256C | |
| 220-1884-ND | LCMXO3L-4300C-5BG256I | |
| 220-1937-ND | LCMXO3L-2100C-6BG324C | |
| 220-1938-ND | LCMXO3L-2100C-5BG324I | |
| LCMXO3L-6900E-5MG324C-ND | LCMXO3L-6900E-5MG324C | |
| 220-1881-ND | LCMXO3L-2100C-6BG256I | |
| LCMXO3LF-4300E-5MG324C-ND | LCMXO3LF-4300E-5MG324C | |
| LCMXO3L-9400E-5MG256C-ND | LCMXO3L-9400E-5MG256C | |
| LCMXO3L-4300E-6MG324I-ND | LCMXO3L-4300E-6MG324I | |
| 220-1886-ND | LCMXO3L-6900C-5BG256C | |
| LCMXO3LF-6900E-5MG256C-ND | LCMXO3LF-6900E-5MG256C | |
| 220-1948-ND | LCMXO3L-4300C-5BG400C | |
| LCMXO3L-6900E-6MG256I-ND | LCMXO3L-6900E-6MG256I | |
| LCMXO3LF-4300E-6MG256I-ND | LCMXO3LF-4300E-6MG256I | |
| 220-2008-ND | LCMXO3LF-4300C-5BG256C | |
| 220-2016-ND | LCMXO3LF-2100C-5BG324C | |
| 220-1939-ND | LCMXO3L-2100C-6BG324I | |
| 220-1941-ND | LCMXO3L-4300C-6BG324C | |
| 220-1942-ND | LCMXO3L-4300C-5BG324I | |
| LCMXO3L-6900E-5MG324I-ND | LCMXO3L-6900E-5MG324I | |
| LCMXO3L-6900E-6MG324C-ND | LCMXO3L-6900E-6MG324C | |
| LCMXO3L-9400E-5MG256I-ND | LCMXO3L-9400E-5MG256I | |
| LCMXO3L-9400E-6MG256C-ND | LCMXO3L-9400E-6MG256C | |
| LCMXO3LF-4300E-5MG324I-ND | LCMXO3LF-4300E-5MG324I | |
| LCMXO3LF-4300E-6MG324C-ND | LCMXO3LF-4300E-6MG324C | |
| 220-1944-ND | LCMXO3L-6900C-5BG324C | |
| 220-2006-ND | LCMXO3LF-2100C-6BG256C | |
| 220-1888-ND | LCMXO3L-6900C-5BG256I | |
| 220-2010-ND | LCMXO3LF-4300C-6BG256C | |
| 220-2018-ND | LCMXO3LF-2100C-6BG324C | |
| 220-2020-ND | LCMXO3LF-4300C-5BG324C | |
| 220-1943-ND | LCMXO3L-4300C-6BG324I | |
| LCMXO3L-9400C-5BG256C-ND | LCMXO3L-9400C-5BG256C | |
| 220-2163-ND | LCMXO3L-9400E-5BG256C | |
| 220-1949-ND | LCMXO3L-4300C-6BG400C | |
| 220-1950-ND | LCMXO3L-4300C-5BG400I | |
| LCMXO3LF-6900E-5MG324C-ND | LCMXO3LF-6900E-5MG324C | |
| LCMXO3L-6900E-6MG324I-ND | LCMXO3L-6900E-6MG324I | |
| LCMXO3LF-9400E-5MG256C-ND | LCMXO3LF-9400E-5MG256C | |
| 220-1952-ND | LCMXO3L-6900C-5BG400C | |
| LCMXO3L-9400E-6MG256I-ND | LCMXO3L-9400E-6MG256I | |
| LCMXO3LF-4300E-6MG324I-ND | LCMXO3LF-4300E-6MG324I | |
| 220-1945-ND | LCMXO3L-6900C-6BG324C | |
| 220-1946-ND | LCMXO3L-6900C-5BG324I | |
| 220-2007-ND | LCMXO3LF-2100C-6BG256I | |
| 220-1889-ND | LCMXO3L-6900C-6BG256I | |
| 220-2021-ND | LCMXO3LF-4300C-5BG324I | |
| LCMXO3L-9400C-5BG256I-ND | LCMXO3L-9400C-5BG256I | |
| LCMXO3L-9400C-6BG256C-ND | LCMXO3L-9400C-6BG256C | |
| 220-2164-ND | LCMXO3L-9400E-5BG256I | |
| LCMXO3L-9400E-6BG256C-ND | LCMXO3L-9400E-6BG256C | |
| 220-1951-ND | LCMXO3L-4300C-6BG400I | |
| 220-2019-ND | LCMXO3LF-2100C-6BG324I | |
| LCMXO3LF-6900E-5MG324I-ND | LCMXO3LF-6900E-5MG324I | |
| LCMXO3LF-6900E-6MG324C-ND | LCMXO3LF-6900E-6MG324C | |
| LCMXO3LF-9400E-5MG256I-ND | LCMXO3LF-9400E-5MG256I | |
| LCMXO3LF-9400E-6MG256C-ND | LCMXO3LF-9400E-6MG256C | |
| 220-1953-ND | LCMXO3L-6900C-6BG400C | |
| 220-1954-ND | LCMXO3L-6900C-5BG400I | |
| 220-1947-ND | LCMXO3L-6900C-6BG324I | |
| LCMXO3L-9400C-5BG400C-ND | LCMXO3L-9400C-5BG400C | |
| LCMXO3L-9400E-5BG400C-ND | LCMXO3L-9400E-5BG400C | |
| LCMXO3LF-9400E-5BG256C-ND | LCMXO3LF-9400E-5BG256C | |
| 220-2023-ND | LCMXO3LF-4300C-6BG324I | |
| 220-2165-ND | LCMXO3L-9400E-6BG256I | |
| LCMXO3LF-6900E-6MG324I-ND | LCMXO3LF-6900E-6MG324I | |
| LCMXO3LF-9400E-6MG256I-ND | LCMXO3LF-9400E-6MG256I | |
| 220-1955-ND | LCMXO3L-6900C-6BG400I | |
| 220-2025-ND | LCMXO3LF-6900C-5BG324I | |
| LCMXO3L-9400C-6BG400C-ND | LCMXO3L-9400C-6BG400C | |
| LCMXO3L-9400E-5BG400I-ND | LCMXO3L-9400E-5BG400I | |
| LCMXO3L-9400E-6BG400C-ND | LCMXO3L-9400E-6BG400C | |
| LCMXO3LF-9400C-5BG256I-ND | LCMXO3LF-9400C-5BG256I | |
| LCMXO3LF-9400E-6BG256C-ND | LCMXO3LF-9400E-6BG256C | |
| LCMXO3L-9400C-5BG484C-ND | LCMXO3L-9400C-5BG484C | |
| LCMXO3L-9400E-5BG484C-ND | LCMXO3L-9400E-5BG484C | |
| 220-1985-ND | LCMXO3LF-6900C-5BG400I | |
| 220-1986-ND | LCMXO3LF-6900C-6BG400C | |
| 220-2027-ND | LCMXO3LF-6900C-6BG324I | |
| LCMXO3LF-9400C-5BG400C-ND | LCMXO3LF-9400C-5BG400C | |
| LCMXO3LF-9400E-5BG400C-ND | LCMXO3LF-9400E-5BG400C | |
| LCMXO3L-9400C-6BG400I-ND | LCMXO3L-9400C-6BG400I | |
| LCMXO3L-9400E-6BG400I-ND | LCMXO3L-9400E-6BG400I | |
| 220-2127-ND | LCMXO3LF-9400C-6BG256I | |
| LCMXO3L-9400C-5BG484I-ND | LCMXO3L-9400C-5BG484I | |
| LCMXO3L-9400C-6BG484C-ND | LCMXO3L-9400C-6BG484C | |
| LCMXO3L-9400E-5BG484I-ND | LCMXO3L-9400E-5BG484I | |
| LCMXO3L-9400E-6BG484C-ND | LCMXO3L-9400E-6BG484C | |
| LCMXO3LF-9400C-5BG400I-ND | LCMXO3LF-9400C-5BG400I | |
| LCMXO3LF-9400C-6BG400C-ND | LCMXO3LF-9400C-6BG400C | |
| LCMXO3LF-9400E-5BG400I-ND | LCMXO3LF-9400E-5BG400I | |
| LCMXO3LF-9400E-6BG400C-ND | LCMXO3LF-9400E-6BG400C | |
| LCMXO3LF-9400C-5BG484C-ND | LCMXO3LF-9400C-5BG484C | |
| LCMXO3LF-9400E-5BG484C-ND | LCMXO3LF-9400E-5BG484C | |
| 220-2166-ND | LCMXO3L-9400E-6BG484I | |
| LCMXO3LF-9400C-6BG400I-ND | LCMXO3LF-9400C-6BG400I | |
| LCMXO3LF-9400E-6BG400I-ND | LCMXO3LF-9400E-6BG400I | |
| LCMXO3LF-9400C-5BG484I-ND | LCMXO3LF-9400C-5BG484I | |
| LCMXO3LF-9400C-6BG484C-ND | LCMXO3LF-9400C-6BG484C | |
| LCMXO3LF-9400E-5BG484I-ND | LCMXO3LF-9400E-5BG484I | |
| LCMXO3LF-9400E-6BG484C-ND | LCMXO3LF-9400E-6BG484C | |
| 220-2128-ND | LCMXO3LF-9400C-6BG484I |
