Howdy. I’m looking for some NAND solutions. I need to output my PCB to 8 fingers, and I need 2GB (16gbit) of flash memory. Making a custom game cartridge that uses SD card protocols. I know just enough to be a little dangerous, but I can honestly say the circuit and PCB aspects I am lacking in knowledge.
Welcome to the DigiKey TechForum. Here are some flash nand memory IC’s to view to see if one may work for your application.
Which actual SD protocols do you need support for? The full SDIO/MMC spec or maybe just the SPI signals.
Thinking you can go two ways, using an eMMC Nand device, or SPI data flash…
Regards,
