Cable length tolerances for Modular Ethernet Cable N001-014-BL from Tripp Lite
If someone is concerned about the length measurement tolerances for the ethernet cable N001-014-BL from Tripp Lite, you can learn below.
Its length is measured from connector tip to connector tip, with a tolerance of +/-50 mm.
Applicable Part Numbers
N001-014-BL
TL1442-ND
