Cable length
------Question for LTMWG946-A3CB3CW3JG2C-WHT-180 Please Put your question below------
Is this the short or long cable version. If short, can you link to long one?
Hello mdowlin, welcome to the Tech Forum! I’m not entirely certain as the datasheet doesn’t call out what lengths the cable can go to. What I can tell you is that the cable is 180 inches long (15 feet total) which is usually considered a “long length” for coaxial cable off an antenna.
Generally speaking, it isn’t ideal to connect several coaxial cables together as you do lose signal integrity down the line due to added resistance. This could change impedance ratings which can cause reflections.
Ah good, that is the long cable version. The other one is only a pigtail that’s only a foot long. Thanks!
Yeah, I may want to shield them somehow as they are pulled.
