Carlo Gavazzi RCP Series Substitute P/Ns
Digi-Key carried the RCP series of socketable power relays from Carlo Gavazzi Inc. They have been obsoleted by the manufacturer. Carlo Gavazzi’s RCI series seems to be a close substitute to consider when looking for a replacement. You can see the RCP series part numbers that Digi-Key carried listed in the below table with the possible substitute part number from the RCI series. To view the product page for each part number, click on the respective Digi-Key part number. The sockets for the RCP and RCI series are also listed below for both the 11 and 8 pin types.
RCP Series Data Sheet: https://www.gavazzionline.com/pdf/rcpn.pdf
RCI Series Data Sheet: https://www.gavazzionline.com/pdf/RCI-2017-DS.pdf
Obsolete P/N Digi-Key P/N Substitute P/N Digi-Key P/N
RCP11003115/120VAC 1864-2685-ND RCI003A120V 1864-2677-ND
RCP11003230VAC 1864-2686-ND RCI003A240V 1864-2678-ND
RCP1100324VAC 1864-2687-ND N/A N/A
RCP1100324VDC 1864-2688-ND RCI003D24V 1864-2681-ND
RCP8002115/120VAC 1864-2689-ND RCI002A120V 1864-2671-ND
RCP8002230VAC 1864-2690-ND RCI002A240V 1864-2672-ND
RCP800224VAC 1864-2691-ND RCI002A24V 1864-2673-ND
RCP800224VDC 1864-2692-ND RCI002D24V 1864-2675-ND
RCP Series Sockets
11 Pin: ZPD11 (Digi-Key P/N 1864-2875-ND)
8 Pin: ZPd8 (Digi-Key P/N 1864-2876-ND)
RCI Series Sockets
11 Pin: ZCI11 (Digi-Key P/N 1864-2869-ND)
8 Pin: ZCI08 (Digi-Key P/N 1864-2868-ND)
