Chogori 2 Pin circular connector Y harness or parts
I am looking for chogori Y harness as pictured or individual connectors and I can make my own y harness.
The orange connector looks like 22002231 but I cannot find the mating connector listed.
The Y harness looks made by chogori, the union moulding is stamped with their logo
Any help appreciated.
22002(3)231-01.pdf (144.0 KB)
looks like a combination of
and
Splitter-Chogori Technology Co., Ltd
Welcome to the DigiKey TechForum. It looks like DigiKey part 2150-22002231-01-ND that you found is correct and I found the male version, DigiKey part 2150-22002311-01-ND . I wasn’t able to find this in a cable assembly form but with the connectors you may be able to make the assembly.
Hello Steve,
Thank you for your reply. It would be no problem to make a Y harness if I could purchase the correct connectors however the male plug you listed does not match what is in the pictures.
Looking at the data sheet for:
22002231-01 – 2 This is the orange side description is standard series push lock male plug with female pin. (*This is the style push lock I need both ends for)
Data sheet for the connector you provided:
2150-22002311-01-ND Description is standard series screw female plug with male pin.
(*It does not look like the standard series screw will connect to standard series push lock.)
Can you please advise what the correct push lock mating connector would be for 22002231-01 – 2 would be?
Thanks,
Craig Werger
Hi Steve, Did you see my reply. The connector you listed does not seem to be a match.
Thanks
Craig
Hi cwerger,
Could it be the 22002331-01? Seems right to me.
Yes that looks correct. Thank you!!
