A question that comes in the Application Engineering department from time to time is whether customers have received the correct connector as the color is not exactly the same as the previous connector.
One recent question I had was on Digi-Key part number WM13113-ND, Molex part number 0039012206.
The customer was concerned that the part he received was not an OEM part as the color was not the same shade of white as a previous connector. This is not the case. Molex sources multiple plastics to meet their customer needs and all of them pass the same tests and are held to the same standards, however they do have some variations in color. Here is the example picture they give for the UL-94 V-0 Mini Fit Jr materials:
As you can see there are some slight differences in coloring.
Here is the complete Molex Color Variation Document.
Mini Fit JR Color Variations.pdf (30.9 KB)
Should you have any questions about your parts please feel free to ask right here on the Digi-Key TechForum.
Applicable Mini Fit Jr Part Numbers
WM3700-ND WM18434-ND WM1021-ND WM3701-ND WM18439-ND WM1030-ND WM1018-ND WM3600-ND WM3601-ND WM24034-ND WM1031-ND WM2837-ND WM3703-ND WM3704-ND WM3702-ND WM23700-ND WM23701-ND WM23608-ND WM23703-ND WM23702-ND WM23705-ND WM13992-ND WM13486-ND WM18437-ND WM13487-ND WM1022-ND WM16165-ND WM12978-ND WM18435-ND WM18440-ND WM6679-ND WM18441-ND WM18436-ND WM1019-ND WM16164-ND WM23600-ND WM3604-ND WM4369-ND WM12736-ND WM3603-ND WM1056-ND WM23612-ND WM13116-ND WM2838-ND WM13488-ND WM1020-ND WM13490-ND WM3605-ND WM14874-ND WM23601-ND WM23609-ND WM13114-ND WM3705-ND WM23610-ND WM9879-ND WM23611-ND WM16166-ND WM23613-ND WM24062-ND WM16260-ND WM3706-ND WM24065-ND WM3709-ND WM24063-ND WM3707-ND WM23603-ND WM3708-ND WM23604-ND WM23704-ND WM23606-ND WM4379-ND WM23706-ND WM3607-ND WM3711-ND WM23707-ND WM23607-ND WM23708-ND WM23711-ND WM23709-ND WM12773-ND WM13113-ND WM16239-ND WM16167-ND WM13115-ND WM16169-ND WM16171-ND WM16258-ND WM16259-ND WM17197-ND WM17196-ND WM11175-ND WM7262-ND WM18438-ND WM3602-ND WM24061-ND WM1057-ND WM3606-ND WM23602-ND WM24064-ND WM23605-ND WM3710-ND WM13489-ND WM1012-ND WM1028-ND WM1013-ND WM1029-ND WM23710-ND WM4370-ND WM11176-ND WM16170-ND WM10848-ND WM17278-ND WM17277-ND 0469990655-ND 0039014020-ND 0469990290-ND 0469990658-ND 0469990276-ND 0039014021-ND 0469990561-ND 0469990277-ND 0039015039-ND 0945579004-ND 0469990291-ND 0469990293-ND 0039016030-ND 0469990503-ND 0039039022-ND 1726460412-ND 1726460402-ND 0469990279-ND 0469940512-ND 0050361734-ND 0039014060-ND 0039039102-ND 0039039122-ND 0050291599-ND 0469990294-ND 0469990301-ND 0050304446-ND 0469990295-ND 0469990278-ND 0039028020-ND 0050361679-ND 0768190001-ND 0455870003-ND 0050304447-ND 0003044052-ND 0050361681-ND 0050291663-ND 1726460313-ND 0039039082-ND 0050361893-ND 0050361737-ND 0039012186-ND 0469930811-ND 0469930611-ND 0039013066-ND 0469990296-ND 0050361869-ND 0039013125-ND 0469931011-ND 0039028065-ND 0469990280-ND 0469990297-ND 0050361674-ND 0039039142-ND 0039013145-ND 0469990282-ND 0039013225-ND 1726460413-ND 1726460513-ND 0039013189-ND 0469930810-ND 0449910001-ND 1726460312-ND 0039013203-ND 0469990298-ND 0469921400-ND WM16168-ND 0039039242-ND 0469931410-ND 0469931210-ND 0469931811-ND 0469931211-ND 0469921610-ND 0469931810-ND 0469931611-ND WM16144-ND 43511-0001-ND WM1058-ND WM4265-ND WM7261-ND WM7263-ND WM7264-ND 0050290092-ND 0050361667-ND 0050361668-ND 0050361675-ND 0050361676-ND 0050361677-ND 0050361682-ND 0050361716-ND 0050361735-ND 0050361736-ND 0050361738-ND 0050361739-ND 0050361746-ND 0050361876-ND 0015046020-ND 0015046021-ND 0026013093-ND 0026013096-ND 0026013167-ND 0026013187-ND 0050361666-ND WM11174-ND 0050362301-ND
39-01-2020 0039014030 0039013022 39-01-2040 0039014036 0039013023 0039013043 39-01-2021 0039012041 0039013029 0039013063 0039013028 39-01-2080 39-01-2100 39-01-2060 0039012025 39-01-2045 0039014031 39-01-2085 0039012065 0039012125 0469990275 0039013025 0039014032 0039013045 0039013042 0469920410 0039039062 0039014040 39-01-4046 39-01-6026 39-01-4056 0039014050 0039013083 0469920210 0039012026 0039012101 0039013048 0039013026 39-01-2081 39-01-3123 0039014047 0039039042 0039014037 0039013085 39-01-3103 0039014057 39-01-2121 0050291662 39-01-2046 0039014041 0039014043 39-01-2120 0039014051 0039013105 39-01-4033 0469920610 39-01-4053 0039013069 0469930610 39-01-2140 39-01-3129 39-01-2200 0039013089 0039012160 0039012086 39-01-2180 39-01-2106 39-01-2105 39-01-2146 0039013149 0039012145 0039012161 0039012240 0039012165 0039012166 0039012185 0039012245 0039012205 0469922410 0039012206 0039013065 0469920810 0039027028 0469930210 0469930411 0469921010 0469930410 0469931010 0469921410 0050361678 0050361671 39-01-4052 39-01-2061 0039013049 39-01-3143 39-01-2141 39-01-2066 39-01-3109 39-01-2126 39-01-2220 0039013183 39-01-2181 39-01-2201 39-01-2221 39-01-2241 39-01-2225 0039012246 0050361713 0469930211 0455590002 0469940412 0469921210 0469990655 0039014020 0469990290 0469990658 0469990276 0039014021 0469990561 0469990277 0039015039 0945579004 0469990291 0469990293 0039016030 0469990503 0039039022 1726460412 1726460402 0469990279 0469940512 0050361734 0039014060 0039039102 0039039122 0050291599 0469990294 0469990301 0050304446 0469990295 0469990278 0039028020 0050361679 0768190001 0455870003 0050304447 0003044052 0050361681 0050291663 1726460313 0039039082 0050361893 0050361737 0039012186 0469930811 0469930611 0039013066 0469990296 0050361869 0039013125 0469931011 0039028065 0469990280 0469990297 0050361674 0039039142 0039013145 0469990282 0039013225 1726460413 1726460513 0039013189 0469930810 0449910001 1726460312 0039013203 0469990298 0469921400 0469921810 0039039242 0469931410 0469931210 0469931811 0469931211 0469921610 0469931810 0469931611 0039012226 43511-0001 39-01-3163 0050361672 0050361669 0050361673 0050362293 0050290092 0050361667 0050361668 0050361675 0050361676 0050361677 0050361682 0050361716 0050361735 0050361736 0050361738 0050361739 0050361746 0050361876 0015046020 0015046021 0026013093 0026013096 0026013167 0026013187 0050361666 0050304461 0050362301
