Compatible replacement
looking for compatible replacement and part# part # ends with F
OSG60R380F-datasheet-pdf-www.findic.us.pdf (970.6 KB)
Hello apelow. Welcome to DigiKey’s TechForum!
We don’t have a direct equivalent to OSG60R380F, but we do have a couple of substitutes you can take a look at. FCPF7N60 and FCPF400N60 are two possible substitutes. These are not direct crosses, so you will want to compare datasheets to verify either of these substitutes is appropriate for your application.
