Create a generic sdcard.img file
Create an initial sdcard.img file:
To create an initial 2GB sdcard.img file, use fallocate, you can use the -l operator for lenghth. In this case use 2G for a 2GB sdcard.img:
fallocate -l 2G sdcard.img
Double check sdcard.img file with fdisk:
sudo fdisk -l ./sdcard.img
Disk ./sdcard.img: 2 GiB, 2147483648 bytes, 4194304 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
At this point, if need to dd data directly to the sdcard.img, you can otherwise, use the disk tools to create the partition table:
For example, to create a ext file system with a 1MB offset:
sudo sfdisk ./sdcard.img <<-__EOF__
1M,,L,*
__EOF__
Example, output:
Disklabel type: dos
Disk identifier: 0x2bb23543
Device        Boot Start     End Sectors Size Id Type
./sdcard.img1 *     2048 4194303 4192256   2G 83 Linux
However for any further operation we need to use losetup/kpartx:
Grab an open loop device with losetup
If you are running ubuntu or anything with snap running, /dev/loop0 will defintelly not be open:
Typical non-ubuntu or without snap installed:
sudo losetup -f
/dev/loop0
Typical ubuntu or distro with snap installed:
sudo losetup -f
/dev/loop5
losetup: attache sdcard.img file with a loop device:
sudo losetup /dev/loop0 sdcard.img
kpartx add partition devmappings from loop device:
sudo kpartx -av /dev/loop0
Example, with our above partition, kpartx will output:
add map loop0p1 (254:0): 0 4192256 linear 7:0 2048
loop0 should now show up under /dev/mapper/loop*, this where we can actually mount and work with the partitions on sdcard.img file:
ls /dev/mapper/loop*
/dev/mapper/loop0p1
To format, /dev/loop0p1, run;
voodoo@hestia:~/testing$ sudo mkfs.ext4 -L rootfs /dev/mapper/loop0p1
mke2fs 1.46.2 (28-Feb-2021)
Discarding device blocks: done
Creating filesystem with 524032 4k blocks and 131072 inodes
Filesystem UUID: 8b0688fe-d2c3-4cb2-98d7-04d42fe529a0
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: do
To mount, /dev/loop0p1, run;
sudo mount /dev/mapper/loop0p1 /media/rootfs/
You will no see it mounted:
voodoo@hestia:~/testing$ mount | grep rootfs
/dev/mapper/loop0p1 on /media/rootfs type ext4 (rw,relatime)
Copy your data as is at this point..
To umount and disconnect the sdcard.img, run everything backwards:
First unmount devmappings
sudo umount /dev/mapper/loop0p1
kpartx: delete the partition devmappings
sudo kpartx -d /dev/loop0
losetup: detach loop device:
sudo losetup -d /dev/loop0
#Complete:
Use any tool, dd/etcher.io to flash the sdcard.img file to your microSD card..
