CRIMPFOX MT 2,5 (1204038) replacement
Hi all,
I’m looking for the correct crimping tool for Phoenix Contact 3190603 (ICC-MT 0,5-1,0 BA, DigiKey 3190603-ND), 0.5–1.0 mm² / AWG 20–18.
The Phoenix accessories sheet for the loose version (3190577) lists the CRIMPFOX MT 2,5 pliers (1204038) as the crimping tool. However, that tool and its replacement die (1208050) seem to be discontinued at most distributors, and the Phoenix product page no longer loads.
Questions:
  1. Is there a current Phoenix (or approved third-party) hand tool for ICC-MT 0,5-1,0 contacts?
  2. Does anyone know why 1204038 was discontinued, or what replaced it?
Thanks in advance!
Hello @sahan.g,
I put in a request with the supplier. It might take a few days to get an answer on this.
Thanks,
Jeff
Thank you Jeff, Kindly let me know soon as you hear something.
Per the manufactuer, For the ICC-MT 0,5-1,0 BA crimp contact, we recommend using the TE Connectivity crimping tool to ensure proper and reliable termination of the contact. Please ensure that the proper crimping die is installed and used with the tool to achieve the correct crimp profile and performance.
58433-3 : AMP Hand Crimping Tools | TE Connectivity
Hi Jeff,
Thank you for the information.
58433-3, is the hand tool with a die which is used for quick connectors (Insulated Terminals).
Can you kindly assist us on finding the right die set for this hand tool frame.
I will ask the supplier again.
The tool the manufacture recommended is 539674-2 but it is obsolete. It has been superseded by 2390879-1 The replacement should work for the part.
