The KAMAYA RLC32K1R00GTP is a 1Ohm 2% 1/W 1206 AEC-Q200 Current Sense Resistor.
If you are looking for an alternative to this product, you may consider the ERJ-8BQF1R0V from Panasonic. Please refer to the datasheet and specifications to determine if this resistor will work for your application.
Please review the datasheets to ensure the alternative will work for your application.
KAMAYA_2011_E_1025.qx.pdf (80.9 KB)
