Current derating
------Question for WP86SD-S080VA1-R20000 Please Put your question below------
What is the pin derating graph of pin resistance versus current and temperature? I want to use the connector over the 300mA limit in a cold application. Thanks
welcome to the TechForum.
I was not able to find that information in the documents we have or on the manufacturer’s website. I do have their link below for some extra information on this part.
WP86SD-S080VA1-R20000 | Connectors - JAE Japan Aviation Electronics Industry, Ltd.
I also can email our Product Manager in charge of this line and request this information and see if JAE Electronics can supply this. I would expect a 2-3 day turnaround for this email chain to come back.
Thank you
Ryan
Thank you. I appreciate the fast response! If JAE can supply this info, it would be great. I understand there will be a few days turnaround. I am used to having derating curves on connector contacts, not just a max current rating. Jim
We heard back already and this was the response : Thank you for inquiring about WP86SD-S080VA1-R20000.
“What is the pin derating graph of pin resistance versus current and temperature? I want to use the connector over the 300mA limit in a cold application”.
For this we do not have a graph, but JACS should be sufficient.
Thank you
Ryan
